E28 535 Motormounts(Green) Can i use these with m20 short period?
  • Pettas
    • Dec 2004
    • 41
    Motormounts... I am doing the m50 swap very soon, so i have the big green heavy duty motor mounts for that. BUT, I got 1 more race this weekend before i gut it of its eta heart, and I also have a torn motor mount which wont let me be able to race. Can i use the e28 motor mount for this weekend
    The problem is, I am not sure how it would sit, plus the mount is about a half an inch taller than the m20 ones, so it would put the motor up higher, need your help, thanks.
  • Jordan
    • 12916
    I think if you really must race then the mount will do what it needs to for the weekend. There is quite a bit of room above the manifold before hitting the hood so you should be just fine.
    https://mtechniqueabs.com/
    • Pettas
      • Dec 2004
      • 41
      Oh, well, I didnt know if the engine being elevated up half an inch more would put any weird strain on the tranny, or driveshaft. Any thoughts of that?
      • Jordan
        • 12916
        No more then a sagging stock mount that slips off and rests the pan on the subframe while the clutch fan chews the radiator up?
        • Pettas
          • Dec 2004
          • 41
          Oil pan doesnt rest on subframe, but your right about the fan chewing up the radiator, only under hard braking though.
