Sooo... my x20 plug has not got pin 8
  • Jib05
    • Aug 2012
    • 149
    so Ive been tackling this x20 > c101 plug adapter for my m50. Ive had a look at the wiring diagrams on
    and have a few of other peoples pin-out diagrams to compare with. For example
    and also
    so pin 8 on x20 is the engine check light and the x20 i have has a blank plastic rather than a pin. The car its going into is a 1988 PFL e30 320i. The x20 is from an e34 1995 (where I got the motor from).
    just wondering if there is something I'm missing. Thanks for your time!!
    Jib.
    .................................................. ...................sigpic
    .................................................. ............................. ......M50B25 3.1L stroker
    • 34844
    euro cars often have no CEL. not a big deal to leave out if your don't have it anyway.
    • Jib05
      • Aug 2012
      • 149
      OK cool!! thanks for the quick response. :D
      Another inquiry if i may, there is a +12v wire on the x20 on pin 3(red). Does it need to go anywhere? Or could it be used to power the 3 relays that come with the m50 motor.
        • 34844
        relay power will generally come from a post that goes to the battery terminal, not through the X20. you usually match wires that go to the C101, not the X20, because the X20 has a lot of pins that you don't need.
        • Jib05
          • Aug 2012
          • 149
          ok thanks again! helped a lot.
