s50 w / euro 323 fw...how to lock flywheel?
  • JRKOUPE
    • Dec 2004
    • 3159
    Im taking my time doing a HG job on my s50 swap track car w/ some part time help from a bmw tech.......
    I run a euro 323 flywheel, ...how does one lock this flywheel...?
    ...the dowel/pin to use w/ the s50 block is not inserting into my fly to lock it?....
    pls advise....thnx.
  • FredK
    • 14762
    You don't have to lock the flywheel.
    You'll have to set TDC using the match marks on the harmonic damper and the front timing cover.
    http://www.pelicanparts.com/bmw/tech...oval/pic19.jpg
    • BenM
      • 2184
      Fred is spot on.
      Not only that, but you get it close enough and then put the cam blocks on pretty easily.
      And when the cams need to come out (after you pull the vanos), you'll have to take it out of TDC so that none of the valves collide with the pistons when you rotate the cams individually. I can tell you this since I just swapped cams in my M50TU.
      The Pelican Parts method is also very good, I would check that out as well.
      Originally posted by BillBrasky
      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
      1991 318i Alpine II - S50/5-lug swapped - track car
      1989 325i Cirrusblau - Daily
      1970 2500 - Malaga over Grey Cloth
      2012 F350 6.7PSD
      • JRKOUPE
        • Dec 2004
        • 3159
        s50
        many thanks......!!!!......
        • Wanganstyle
          • 2828
          Originally posted by BenM
          Fred is spot on.
          Sent from my GT-N7100 using Tapatalk 2
          If the head is coming off for hg swap and the cams have to come out for some reason (they dont need to as head bolts just come out through clearances) doing cam change with head on bench is much much easier.
          Changing camshafts in the car must be a PITA to line up all lifters esp on exhaust side. Joys of slant 6!
