VSS OBDII wiring questions.
    • 34839
    the OBDII dme's should be well known by now, no?
    • dmjensen
      • Jan 2011
      • 805
      Originally posted by 328ijunkie
      Finding that byte is the fun part ;-)
      Oh you turd. Well, if your saying it doesn't need to be an accurate signal just a signal of movement to get rid of the check light then I think that pin # 20 x20 will be the ticket.
      • dmjensen
        • Jan 2011
        • 805
        I was was wrong, 20 x20 goes to pin 36 x6000 and according to the pin outs on that connector its engine speed (rpm)
        • evandael
          • Oct 2009
          • 2881
          can anyone comment on why the ETM says the DME VSS input is on pin 171?
          the x6000 only has 88 pins.. but does it have 88 inputs as well, yielding 176 total 'connections', as seen in this image? (note, i cut off the bottom of the page, this is page 1210.20-c)
          • dmjensen
            • Jan 2011
            • 805
            not sure what you found there but your right that is strange, but I just flipped through the etm fast and couldn't find any pins going to the DME (besides the pin out above) that go higher then 88....
            328junkie, I found that #9 in x20 leads to pin 15 x6000 (right rear speed sig) and to pin 15 x1171 also rear speed signal. Is that the pin you speak of? because that would explain why you need to convert the signal.
            • evandael
              • Oct 2009
              • 2881
              unless it is internally jumpered, i cannot figure it out.
              SPECULATION ALERT
              it's possible, that given other people's success with the swap, that with x6031p3, 'TI measurement fuel signal' is actually just a different name for VSS output from the e36 cluster.
              /speculation
              that still doesn't fix the difference in frequency noted between the e30 VSS and the req'd e36 VSS, but maybe one could hook up a diagnostics system and see if there is a difference between using the e30 VSS from the diff sensor and using a conditioned ABS signal.
              you found x20p9 which is the wheel speed signal that i believe is used in the ASC system. a signal from an ABS sensor would need to be conditioned, however, using x20p9 would likely not solve your VSS problems.
              x20p20 is an RPM output, not VSS input. not sure why that is being used.
                • 34839
                SPECULATION ALERT
                /speculation
                no. the TI signal is a conditioned fuel injector pulsewidth that the cluster/OBC turns into an MPG reading.
                • evandael
                  • Oct 2009
                  • 2881
                  ^ okay, and since there is no black/white VSS wire in the x6031 (both in dmjensen's image and in the ETMs).. it remains a mystery.
                  • dmjensen
                    • Jan 2011
                    • 805
                    Its no mystery, its in the x20 connector. The e36 dme just uses a different signal apparently.
                    • evandael
                      • Oct 2009
                      • 2881
                      so is it x20 pin 9, or x6031 pin 3?
                      have you wired it up?
                      • Gooch
                        • Dec 2006
                        • 1674
                        Pin 3 on the x6031.
                        '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                        '87 535i - Vacuum brake conversion [SOLD]
                        '93 525iT - 5-speed swap - 320k and counting
                        '09 328xi - 6-speed
                        • dmjensen
                          • Jan 2011
                          • 805
                          Pin 3 on x6031 is a fuel compsumption signal, only reason it works is because its giving the computer a signal that isnt 0 voltage. I'll try both pin 9 x20 and pin 3 x6031. I will report my findings after hooking up inpa while driving around to look for a semi accurate speed signal.
                          • mammoth_e30
                            • Nov 2009
                            • 818
                            Any report on this? I still have the P0500 code coming up. I have read and reread the e36 obd2 ETM and x6031p3 has to be the VSS/speed signal. Why this works for some people and not others is a complete mystery to me.
                            Pin x20p9 is ABS/ASC from what I have seen, I would make an assumption this won't fix our problem but if by chance it works....
                            My smog is due this month and I have not been able to get to the BAR referee because of this damn check engine light so I am up a creek without a paddle and will either pay out the ass for smog or find a way to register my car out of state.
                            • chris_rai
                              • Sep 2009
                              • 99
                              me too i got a code :
                              VSS signal not OK / ready, hitting the rev limiter a little earlier
                              fuel trims too, looks very innacurate
                              • luckysnafu
                                • Jun 2008
                                • 262
                                I have pin 9 of the X20 (white/gray with yellow dashes) connected to pin 14 of the C101 (black/white) and I don't get any codes or problems with rev limiting. I have an early 96 m52 engine with OBDII still wired up.
                                I can verify via the Android Torque app that my ecu is receiving the speed signal. From another thread (http://www.r3vlimited.com/board/showthread.php?t=264748) we determined the following:
                                48 pulses for e30 and 9 for the e36 equals a ratio of 5.33333. If you enter this into the Torque app speed multiplier you will get your actual speed. The e36 ecu doesn't care what signal it's getting, as long as it gets one, as others above have stated.
                                Hope this helps clear things up.
                                M/S52 Wiring Diagrams
                                Z3M S52 to late model 325i wiring diagram
                                M52 to 318is wiring diagram
