Exhaust a bit too loud (maybe wrong sub-forum?)
  • craiggroves91
    • Oct 2009
    • 3024
    Hey guys so as the title says my s52's exhaust is a bit too loud as is, I love the sound (tone) it makes and wouldn't mind the loudness, but sadly I share the road with cops and don't want to attract attention.
    It's not very loud when you are cruising, but when any gas is given its loud. When you go WOT its bat shit insane. It's hard to start out quietly.
    The best vid I have of it ATM
    I need to bring the dB's down a bit, quite a bit. So here is my current setup...
    Stock OB2 exhaust manifolds -> 2 2 1/2'' piping -> 2 2 1/2" in 3" out Y-pipe -> 3" piping -> 3" in/out Vibrant Ultra Quiet Resonator ->3" piping -> 3" in/ dual out Vibrant Stealthpower Muffler
    I'm not sure what I should add.
    Another Vibrant Ultra quiet resonator?
    Or a more traditional longer resonator?
    http://thmotorsports.com/vibrant/vib.../i-295018.aspx
    A muffler like this? (don't think this would do enough) http://www.ebay.com/itm/Vibrant-1769...2ba818&vxp=mtr
    A magnaflow glass pack?
    I'm leaning more towards an additional resonator, probably the longer vibrant one.
    What do you guys think?
    -Craig
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • wholethingoff
    • Mar 2012
    • 128
    orgasmic.
    Muffler? Steel wool?
    • craiggroves91
      • Oct 2009
      • 3024
      Originally posted by wholethingoff
      orgasmic.
      Orgasmic? haha
      The reason I like resonators over mufflers is that I believe they are quite a bit lighter, but probably don't deaden the sound as much as a muffler.
      1989 BMW 325i SOLD
      • pandaboo911
        • 2070
        I'm assuming that muffler is a straight through design. Get a traditional style non performance muffler.
        • craiggroves91
          • Oct 2009
          • 3024
          Well I'm definitely not changing the rear muffler now. So I have to add something on.
          1989 BMW 325i SOLD
          • fronton
            • Oct 2009
            • 1262
            Do you have a cat? If you don't want to change mufflers, perhaps switch the UQ res for a traditional muffler in the middle that is not straight through. If you have any straight pipe longer than 18", I'd try a regular tube type resonator like that vibrant one only longer. My understanding is they are only helpful if 18"+ otherwise you'd be better of with another UQ.
            • craiggroves91
              • Oct 2009
              • 3024
              No cat. I wanted to add a high flow, but they don't sell to CA.
              Well I'd rather not take things off that are already on, like i mentioned above. I mean if I have to I guess I will.
              I'll get under there now and see if I have room for a long bottle type resonator.
              If not, you're saying add another UQ res?
              1989 BMW 325i SOLD
              • fronton
                • Oct 2009
                • 1262
                Regardless of the combo of straight through mufflers and resonators you have, a 3" pipe is going to be on the loud side at WOT. Your best option for serious db reduction is a non-straight through muffler either in the center or swap out the rear. I don't think adding another UQ or bottle type res will be a significant help, maybe reduce a few more high frequency waves but overall db might only reduce a further 5-10%. If you really want quiet, put a big baffled magnaflow or borla xs where the UQ res is.
                • craiggroves91
                  • Oct 2009
                  • 3024
                  Well I don't mind the loudness at WOT as much as I do the loudness during normal acceleration. 5-10% reduction would probably be enough, I don't want quiet per say, just more quiet than it is.
                  It looks like a 22" bottle resonator might fit in one section before the muffler and after the UQ res.
                  1989 BMW 325i SOLD
                  • fronton
                    • Oct 2009
                    • 1262
                    I think this vibrant res will be sufficient then. I just went from a 14" magnaflow straight through to a 18" and just those 4 extra inches (160 sq in) dropped my db by 5-10%. I don't have experience with tube resonators though so you may want to get more opinions than mine or call vibrant and ask which is more effective as a second res.
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      Yeah, I'm thinking that one should do the trick. The 22" should fit, but I might just go with the 18". Sucks my exhaust is quite low and that will make it even lower in one of the lowest spots, can't do much about that though.
                      I might have to go talk to my exhaust guy to see what would be easier/better. It looks like another ultraquiet res will fit next to the existing one with some modification.
                      I appreciate your input! Thanks!
                      You think if I can get a high flow cat shipped here that would be just as effective or more effective at bringing the noise down?
                      1989 BMW 325i SOLD
                      • Rc 415
                        • Jun 2011
                        • 723
                        C'mon man that's not loud at all! :D lol
                        1987 Delphin 325IS
                        LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
                        Build Thread
                        1993 alpine 2 325IC
                        •Ground control coilovers•16" BBS RS• momo woodgrain
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          haha listen to it in person
                          1989 BMW 325i SOLD
                          • Rc 415
                            • Jun 2011
                            • 723
                            Louder than the turbo setup I was running?? It can't be as loud as the ls1 cops break their necks every time they go past me haha
                            1987 Delphin 325IS
                            Build Thread
                            1993 alpine 2 325IC
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              Umm can't remember, the turbo was loud though!
                              Luckily I haven't been around many cops (knock on wood), but it would should grab their attention.
                              It's quiet while cruising at lower speeds, but if I have to stop and start out again, I'm done for
                              1989 BMW 325i SOLD
