Hey kids, 944 booster don't fit
  • ZekeTheSneak
    • 1562
    porsche 944 booster, Akg motormounts.
    First of all I have been having a hell of a time with motor mounts and boosters. I finally got me some akg motormounts which god damn they fit great. Fuckyou R3vshift!. Anyways my 944 booster still hits so I'm going to space up the drivers mount a bit, I'm just tired of fucking with this and I want to drive it. It's been how long since people started swapping these and still nothing fits perfect? Anyways /rant and a little fyi to those running the 944 booster.
  • 36brua
    • 689
    mine fit great. same set up. shaved fins smooth. Maybe chk, from under the car, to see that the engine is on centerline and not cocked to the the side.
    My CA legal M60 swap
    The happening in our garage
    • Exodus_2pt0
      • 5943
      If you want perfect fitment, buy a car that came with the engine you want from the factory.
      No E30 Club
      • pandaboo911
        • 2070
        Mine fit, is that the ATE booster?
        I shaved fins too
        • ZekeTheSneak
          • 1562
          It was the other one, I had the rod rewelded. Good one exodus....
          • e30rapidic
            • 2167
            mine fit without shaving fins.
            '87 325ic, powered by S50.
            • wenbeaver89
              • Jul 2012
              • 319
              mine fit perfect. Exodus is right too check thats its lined up right!!
              • Mr.SWISS
                • Nov 2005
                • 1251
                Originally posted by ZekeTheSneak
                Fuckyou R3vshift!.
                lmao
                Originally posted by 325Projectz
                don't listen to the diagram... listen to mr. swiss.
                :nice:
                • ZekeTheSneak
                  • 1562
                  Yah I went back under it with a Prybar seeing what I could do. The front end is perfect visually. The akgs fit perfect, mounts are flush and I checked online to make sure they were oriented correctly. I then used the Prybar to push the trans end around but not much movement. I then added 3 washers to the drivers motor mount and everything fits great. I hope my subframe isn't jacked.
                  • 2mAn
                    SeƱior Mod
                    • 21034
                    glad the spacers helped! I am using the iX booster and keep reading different things about its fitment. my main concern was to use factory parts. I also bought the AKG mounts, hope I dont need to space mine out
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    Make R3V Great Again -2020
                    • berlow94
                      • Jan 2013
                      • 1063
                      You are in the 24v swap thread dummy...
                      The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
                      • GunMetalGrey
                        • Dec 2010
                        • 1499
                        Why the revshift hate?
                        • mtlbloodshot
                          • Jul 2011
                          • 761
                          Should of went with the Audi A4 booster. No fins to cut blah blah, direct fit.
                          MY BUILD THREAD
                          http://www.r3vlimited.com/board/showthread.php?t=235231
                          INSTAGRAM : @luchcolaneri
                          • yahh
                            • Aug 2012
                            • 800
                            I used condor mounts and didn't have to shave anything...
                            s50 86 325e Project
                            S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
                            Feedback Thread
                            • Exodus_2pt0
                              • 5943
                              What makes you think I don't know that?
                              Zeke, glad you got it worked out!
                              No E30 Club
