Crankshaft Bolt
  • 2mAn
    Señior Mod
    • 21006
    Crankshaft Bolt
    Searched and have gotten some idea of what needs to be done. Just have a few questions I need clarified. FYI Engine is out of the car, so no bumping the starter here...
    #1 reverse thread, yes or no?
    #2 where can I get a locking tool to keep the crank from wanting to turn
    #3 new crankshaft bolts readily available?
    any other tips? this is slowing the progress down and Id like to keep the progress going.
    thanks
    Simon
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • 328ijunkie
    • May 2007
    • 3961
    3/4" impact :P
    normal threads
    I made a tool with an old crank pulley and a 6' steel bar.
    Check Us out on Facebook
    Full Product Line Tuning
    • 2mAn
      Señior Mod
      • 21006
      will the bigass impact be enough or do I still need a tool to hold the crank?
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      • bangn
        • Sep 2011
        • 760
        will need a rather large impact gun, put a bolt in the block where the bellhousing mates up, big flat head screwdriver into the flywheel teeth to stop it spinning round
        Boris - 89 E30 325i
        84- E30 323i
        • F34R
          sLaughter
          • 12376
          I get them off with an impact every time.
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • 2mAn
            Señior Mod
            • 21006
            3/4" drive Impact knocked that fucker right off:up:
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • dsobering47
              • Oct 2007
              • 697
              Youre never supposed to use an impact gun on any crank-related bolt. You risk the thrust bearings and its the cheap, inexperienced backyard way of removing those bolts. I screwed it 3 bolts to the crank hub and locked the engine with a prybar against the frame rail. Then a 1/2" breaker bar with extension to release torque on the bolt. PB blaster never hurts.
              • 2mAn
                Señior Mod
                • 21006
                new bearings are going in so I wasnt worried about that
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • 7pilot
                  • 475
                  If the flywheel is still bolted to the crank I use a tool made from 1/8" steel strap with a hole at each end.
                  One end of the strap is bolted to one of the pressure plate mounting holes on the flywheel.
                  A second longer bolt passes through the strap, some spacers and then through one of the large holes on the block where one of the largest engine/trans fastening bolts threads through. Then a washer and nut is used to cinch up the second bolt.
                  This immobilizes the crankshaft.
                  m
                  • blueapplesoda
                    • Dec 2005
                    • 1904
                    If your oil pan is off, use a 3/8 or 1/2" socket extension and put it parallel with the crank, right up against the counterweight and rotate the crank until the extension is pinned between the counterweight and the block, somewhere near the bottom of the bore. This effectively stops the crank from turning. Then use a breaker bar and undo that crank bolt.
                    similar idea, but this guy uses a hammer
