To all those spark-cover-less guys out there
  • Fusion
    • Nov 2009
    • 3659
    Check your 6th plug hole. My engine started stuttering and I thought a coil went bad but soon learned that there was washer fluid around the 6th plug. Probably a leaking washer line since the pass. side takes longer to spray.
    Doh!
  • bimmer630
    • 1228
    Yeah man, I had some water build up in my spark plug holes, then freeze overnight... the car would run great until the ice melted, about halfway to work.. then start misfiring.
    Got a cover on there now
    • Fusion
      • Nov 2009
      • 3659
      Mine ran fine until the engine got hot and the fluid (although very little of it) started to boil. I guess it then condensed up in the coil plug.
      Glad I found it, I was about to buy a new coil.
      • butters
        • 1202
        Pro tip if you're going to run without it - careful opening a wet hood. I noticed when washing that opening up the hood often results in a drip right onto that location. Covered it since.
        • Mr. Schwarz
          • Nov 2011
          • 153
          Unsure of actual location? Picture? I've been battling a misfire issue.
          • Fusion
            • Nov 2009
            • 3659
            Cylinder nearest to the firewall (in my case).
            Take out the coil, get a good light (used iPhone LED) and look closely for liquid around the sparkplug.
