Need help ASAP
  • nl328i
    • 556
    Need help ASAP
    Hi all,
    I am trying to finish off this s50 swap and I have hit a snag.
    The car starts and runs fine but the temp gauge was not moving at all. Upon research I found out that in order for the e30 temp gauge to work I needed to replace one of the temp sensors (replace blue top with a brown top).
    I did some reading and ordered part number 12621710512. I just got a call from my mechanic who tells me that that sensor will not fit in the place they blue sensor was in in the head. He said its a totally different set up? Did I just order the wrong part? Can someone help me out ASAP? I only have ramp time for so long today and I don't know when I will get it again.
    Thanks very much r3v!!!
    1976 2002, 1987 325is, s50 1991 touring, 1996 328i vert
  • e34_spangler
    • Dec 2012
    • 311
    He's correct. You have a temp sensor for your ecu and one for the guage. It wouldn't hurt to try the new sensor they don't cost that much in the first place
    • nl328i
      • 556
      What? I don't understand your response. I did buy a new sensor. I quoted the part number as I thought that was the correct brown top sensor to use.
      If that's not right what is?
      • ClausE30
        • Sep 2011
        • 981
        Doesn't the brown top need to be rethreaded? I'm not sure the differences between a s50 setup and s52 as I had to rethread my brown top
        91 Alpinweiss2 318is OBD2 S52
        • e30austin
          • 15382
          E36 coolant temp sensor for dme. E30 M20 coolant temp sensor for gauge. S50 should not require any rethreading.
          • e34_spangler
            • Dec 2012
            • 311
            :thumbup:
            • nl328i
              • 556
              My mechanic is telling me it does. Weird.
              Do I have the right part number??
              • Roysneon
                • 4505
                From a quick google search it looks right. Are you sure he's trying it in the right port? Cars and girls both get testy when probes go in the wrong bungs.
                Originally posted by mbonanni
                I am a pursit now.
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5247
                  Middle port in the head? or am I thinking early M/S52's?
                  Originally posted by priapism
                  Originally posted by shameson
                  • nl328i
                    • 556
                    Middle port? I thought there was only two? One for the black sensor (further back on the head) and the blue sensor (closer to the front) with the blue one being replaced with the brown top sensor.
                    I didn't see much about this throughout my early research on these swaps. Everything seems to be working fine except for the gd temp gauge!
                    He tells me that the sensor looks to be much longer as well. He said he might be able to get an adapter or something? I was hoping it would just be a simple sensor change So i could start driving the touring!
                    Does anyone have a diagram that shows exactly where this sensor is supposed to go?
                    • Varinn
                      • 780
                      M/S50's have 3 ports, one DME sensor (m12x1.5), one gauge sensor (m14x1.5) and one TB heater port (m12x1.5)
                      Early M/S52's have 3 with one plugged (m14), one sensor (m12) and one TB heater port (m12)
                      Late M/S52's have 2 holes, one for sensor (m12) and one for TB heater (m12)
                      There appear to be a couple ways to do it if you dont have the early 3 hole head. delete the TB heater and drill/tap to m14x1.5, delete the TB heater and rethread the e30 temp sender to m12x1.5 or run an inline connection block on the TB heater hose. Two hose barbs inline with a hole drilled on the side to allow the temp sender to thread in and measure the coolant flowing to the heater.
                      Here's an example from my early model S52 with the plugged m14x1.5 center port. E30 sender threaded perfectly in the center hole.
                      1990 332i, 4 door
                      2008 KTM 990 Superduke
                      2018 Golf R, 6spd manual (Pending delivery)
                      2017 Mazda CX-5 GT
                      2007 Z4M Coupe - Sold to very nice people
                      • nl328i
                        • 556
                        I have a s50. Does that make a difference?
                        Great info here guys!!
                        • 328ijunkie
                          • May 2007
                          • 3961
                          You need to replace the BLACK sensor with the e30 one...
                          Check Us out on Facebook
                          Full Product Line Tuning
