Power steering lines
  • ClausE30
    • Sep 2011
    • 981
    Hey guys,
    I'm trying to hook up the power steering lines for my s52. I've read the e30 lines work but that some bending may be needed to reach the stock e36 reservoir position. Is the line that needs bending the one coming off the pump to the reservoir? Can anyone shoot a pic of the way you have it routed? Thanks
    91 Alpinweiss2 318is OBD2 S52
  • caesar101
    • Sep 2011
    • 16
    I doubt the e30 line will work, check the pump end size. An e36 line will work, but doesn't look all that good installed. Custom is the best bet if you want it to fit and look OK/
    • 318isbmw
      • Nov 2005
      • 2843
      Right now I'm using stock e36 lines, but on my last swap I ran stock e30 lines and it worked just fine.
      • amcink
        • 788
        Photos please, this is my next challenge
        • ClausE30
          • Sep 2011
          • 981
          I used some heat and a pipe and was able to bend the e30 lines 8-) I just had to bend the line coming off the pump to res
          • Link
            • May 2012
            • 834
            Photos?
            View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
            • ClausE30
              • Sep 2011
              • 981
              I'll get some tomorrow. Still need to hook up everything after having to pull the motor again
              • Link
                • May 2012
                • 834
                Photos still coming for this? Would be great if so!
