Who wants to play "Is This S50 Toast?"...
  • Rsully70sev
    • 2391
    Long story short- deer.swerve.tree.fawked
    Cut off the front end today thinking maybe the tree just took out my intake, I knew the oil pan was cracked, etc but I'm not sure about the rest of the motor. I haven't tried starting it since the accident, it was pissing coolant and oil all over the tow truck's bed.
    I took a sawzall to the entire front end and this is what I found. Any input or inquaries for more photos/information to help would be greatly appreciated. As you guessed I'm sure, insurance is bending me over so I was hoping to recoup some money out of the motor/tranny.
    Accident:
    Cut:
    The oil filter housing and alernator were lose and dangling by their lines.
    Oil pan
  • IRON-E
    • 16548
    Dang man, sorry to see this happen to you. Luckily you're still around to build another one if so desired.
    Good luck on the motor.
    @IRON-E30 aka Edwin:D
    • jp_slick
      • 1089
      Damm dude. My s50 just swallowed a valve, but i couldnt imagine losing my car like that. good luck.
      89 325i S50/ZF E36 M3/TI 5lug Style 32s
      My feedback Thread http://www.r3vlimited.com/board/showthread.php?t=219113
      • Dj Buttchug
        • Jun 2010
        • 7688
        dayumm. thats a hard hit. looking at it closer im seeing slack in the oil pump chain. :( cant be good
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • e30nub
          • Jun 2008
          • 1741
          Such a bummer. +1 on the chain slack. Doesn't look good. Hope to see you cruising around in an e30 soon bud!
          -Pierre
          1987 535is
          1988 325is
          • BenjaminButtton
            • May 2012
            • 275
            The oil pump almost look likes its a little tweaked... I can't tell for sure from the angle of the pic though.
            That sucks hard man :( Must've been quite the hit, are you alright?
            Early models do it better.
            '86 Cosmos Sedan LS1
            • Rsully70sev
              • 2391
              Yea we're definitely lucky to be alive. That's real. Obviously that's what matters most, money comes and money goes, a $10k loss wasn't what I was expecting that evening though.
              Also wondering whether to waste my time pulling it or leave it be. I'm thinking e30 trailer for the rear on the bright side...
              • hooken m
                • 1537
                shit man, glad you're alright. that really sucks man. pull the motor and take the head off and inspect it i guess. its worth a shot to see if anything is salvageable
                Originally posted by evandael
                a car is a car. call it a dildo, i'd still drive the hell out of it.
                • MJCRO
                  • Apr 2012
                  • 597
                  Jesus man, that sucks. I remember I was in Petaluma a few weeks back after visiting a friend in Fairfield and stopped by Bodega Bay to catch some rays. Dang, at least you're alright though. I hope some of your losses get recuperated by the motor.
                  • 10Toes
                    Me Father Was A Tree
                    • Jan 2008
                    • 61222
                    That engine is toast, the block is missing parts of casting but as long as the timing chain is still connected, the head and all the internals could still be fine as long as it was turned off right after the crash and didn't run without oil.
                    • F34R
                      sLaughter
                      • 12376
                      That sucks.
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                      • ttrousdell
                        • Nov 2009
                        • 1770
                        I think youre lucky that the tree seemed to have came into the side of the motor and not strait on. The cleareances in an engine are so tight though i think it would be hard to say for sure unless you took it apart and measured. I hope the engine shut down immediately after the crash.
                        The Build:
                        • golde30
                          • 11464
                          i have an m50 motor that is blown(HG blew and overheat, head is toast) that you could use to frankenstein a motor using your s50 head, assuming its cool.
                          Looks like the oil pan jammed up against the oil pump chain, causing it to skip a tooth, hopefully that extra 1 link worth of slack is just putting tension on the timing chain tensioners...
                          IG: @Baye30
                          • GunMetalGrey
                            • Dec 2010
                            • 1499
                            Not sure, the oil filter housing looks like it left a bit of a mess on its way out.
                            • Rsully70sev
                              • 2391
                              It shut down immediately after the accident. Even two hours later when the tow truck arrived, I still saw oil coming out of the pan. I never tried starting it afterwards. I got my insurance offer back today at $3,100! That's based off of comparable vehicles selling in my area LOL. I told him that's not acceptable and nothing is stock about this vehicle, I'm $16k into the fawker.
