How waffled am I? (s52 oil leak)
  • ClausE30
    • Sep 2011
    • 981
    Hey guys, well with some progress comes setbacks.. I recently dropped my s52 in my car and hooked it all up and filled it up with oil.. I ran the motor for a little bit and I noticed an oil leak.. basically, how waffleswaffleswaffleswafflesed am i? and I'm not sure if the oil pan gasket is the culprit or the lower timing case? pictures below.. Thanks guys
    and heres the amount leaked after engine was run for a minute.. what is weird is that the oil leak hasn't grown over the span of the day today, picture taken just now and not changed from how i saw it this morning.. I just need some incite on where to start. I did not touch the timing case gasket before engine was dropped in, just the oil pan..
    91 Alpinweiss2 318is OBD2 S52
  • e30austin
    • 15382
    Did you silicone the corners of the oil pan gasket?
    • EThirty318i
      • Dec 2010
      • 219
      Looks like the timing cover to me, but when you got it did it show signs of a leak? Did you tighten the oil pan in sequence and to the right specs? might as well replace both while you're at it, thats my .02.
      • ClausE30
        • Sep 2011
        • 981
        yea i put a small dab right at the point of the triple junction.. now that I think about it I might have left it in blob form (not evenly smeared around).. Could that be my problem?
        There was no oil in the engine when I bought it.. oil pan was tightened to spec and in order too
        • EThirty318i
          • Dec 2010
          • 219
          that could have done it, maybe?, but even when you put the pan on it should spread out. then again it might not have made a complete seal or a strong one
          • ClausE30
            • Sep 2011
            • 981
            damn.. Well It would suck if i resealed just the pan and the leak turned out to be the case.
            • kid325e
              • Sep 2007
              • 6422
              Sucks dude! Hopefully it's something that doesn't set you back too far.
              Let us know what route you end up taking!
              clutchCTRL!
              Move with a purpose.
              - 1991 325iX 4dr/5spd
              - 2000 323i AT
              2016 Mazda CX3 Sport AWD
              • kid325e
                • Sep 2007
                • 6422
                Should've just resealed everything you could get your hands on while it was out. Just my .02.
                That's what everyone buying used engines should be doing, unless you know for a fact that everything ran and held fluids the paranoia would kill me!
                What was replaced as far as seals and gaskets go?
                clutchCTRL!
                - 2000 323i AT
                • e30austin
                  • 15382
                  You are supposed to put it on all 4 corners on both sides. I didn't get it good enough on my passenger side rear and its starting to leak a little :(
                  • ClausE30
                    • Sep 2011
                    • 981
                    pretty much everything but that front portion
                    yea I did what the bentley said and put it in all 4 corners. I'm kinda leaning towards not applying the silicone around the corner and just leaving it at the one point.. that would be my optimistic outlook..
                    • e30austin
                      • 15382
                      I didn't do my timing cover gaskets when my S50 was out. They didn't leak. It's really hit or miss with an almost 20 year old motor.
                      I would keep running it and see if it gets any worse. Make sure it isn't coming from the timing chain tensioner and dripping down the block. I had that issue on both my cars.
                      • ClausE30
                        • Sep 2011
                        • 981
                        after further investigation it appears to be leaking from where I indicated it below.. at the far corner of the timing case..
                        • DesertBMW
                          • Aug 2011
                          • 1038
                          you did not put proper amount of silicone on that spot, you should see it squeeze out some once the oil pan is all bolted up.
                          • ClausE30
                            • Sep 2011
                            • 981
                            ^ good to know! Thanks guys for the responses
                            • BenjaminButtton
                              • May 2012
                              • 275
                              Pshhh, that ain't nuthin' but a thang! Oil leaking is just the cars way of protecting itself from rust!
                              But really, if its that small of a leak I wouldn't concern yourself much. Not saying to forget about it, looks like your car is very clean and you most likely want it to stay that way, but it certainly doesn't need to be at the top of your to-do list.
                              On a scale of 1-waffled, you are .5
                              Early models do it better.
                              '86 Cosmos Sedan LS1
