How waffled am I? (s52 oil leak)
so did it end up being the oil pan gasket?
i have the exact same leak. the same spot and it only leaks after i get done driving it just like yours. so i was getting ready to do the oil pan gasket until i read this, now i'm wondering if it is the timing cover.Comment
Yeah I put RTv all the way around the oil pan and heavey in the corners.Comment
yess its the oil pan gasket.. I fixed it by applying more rtv and evenly spreading it around.. I think the first time I forgot to smear the drop of rtv and it didnt seal properly.. lolso did it end up being the oil pan gasket?
I coat the entire block in the right stuff and slap the gasket on there.
They leak because the alum front timing cover and rear main expand/contract at different rates than the cast block thus they bleed through the seam right there :(.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
