84 318 -> OBD 1 M52 swap, wiring help needed
  • 2mAn
    Señior Mod
    • 20989
    Did some searching around and I am hoping to get a few things cleared up. My car is an 84 318 and Im using a 93 E34 Wiring Harness for my OBD1 converted M52. Ive searched a lot, but I dont think Ive got it completely figured out yet. I am getting close
    I've copied wiring arrangement and the wires that DONT match my harness are in bold.
    84 325 pin arrangement on 19 pin rectangular C101
    Pin#---{Color}---Destination/ Purpose
    1---{Blue}---Alternator Charging
    2---{Blue/ Yellow}---Oil Level Sensor (my 84 doesnt have this wire in the connector???)
    3------ Not used
    4---{Brown/ Violet}---Coolant Temperature Sender
    5------Not used
    6---{Green/ Yellow}---Oxygen Sensor Relay
    7---{Red/ Violet (Green/Violet on mine)}---Fuel Pump
    8---{Black/ Yellow}---Starter
    9------Not used
    10---{Green}---Ignition Switch
    11-14------Not used
    15---{ Violet/ Green }----Oil Level Sensor (my 84 doesnt have this wire in the connector???)
    16---{Brown/ Green}---Oil Pressure Switch
    17---{Blue/ White}---Diagnostic connector pin #7 Service Reset
    18------Not used
    19------Not used
    For Tach Signal---Pin 7 on C-1 blue 25 pin connector on instrument panel
    93 525i pin arrangement on 25 pin round X20
    1---{Blue/ White}---Oil Level Sensor (static)
    2---{Blue/ Green}----Oil Level Sensor (dynamic)
    3---{Red/ White}---ABS/ Slip Control Module
    4---{Black/ Blue}---Transmission Control Module
    5---{Black/ Gray}---Aux Fan
    6---{Violet/ Gray}---?????
    7---{Black/ Violet}---SI Reset
    8---{Green}---Check Engine Light
    9---{Green/ White}---Oil Temp Sensor
    10---{Brown/ Black}----Instrument Cluster/ Check Control
    11---{Brown/ Green}---Engine Coolant Temp Sensor
    12---{Brown/ Violet}---Engine Coolant Temp Sensor
    13---{Green/ Violet}---Fuel Pump Relay
    14---{Black/ White}---Speed Sensor
    15---{Black/ Green}---Starter
    16---{White/ Green}---Data Link
    17---{White/ Violet}---Data Link
    18---{Black/ Green}---Voltage during startup
    19---{White/ Green}---Diagnostic Plug
    20---{Black}---Engine Speed- Tach
    21---{Green}---Ignition Switch
    22------????????
    23---{Brown/ Green}---Oil Light
    24---{White/ Black}---Fuel Rate output
    25---{Blue}---Alternator
    Heres what my adaption will look like (probably using an old Rectangular C101 engine side plug)
    C101 Pin # & Color___Job___X20 Pin # & Color
    1__Blue_________Alternator Charging______25_Blue
    2__Blue/ Violet___Oil Level Sensor (static)__1__Blue/ White***
    3_______________Not used___________
    4_Brown/ Violet__Coolant Temp Sensor____12_Brown/ Violet
    5______________Not used____________
    6_Green/ Yellow__Oxygen Sensor_________?????????
    7_Green/ Violet___Fuel Pump_____________13_Green/ Violet
    8_Black/ Yellow___Starter_______________18_Black/ Green
    9_______________Not used_____________
    10_Green________Ignition_______________21_Green
    11-14___________Not used______________
    15_Violet/ Green___Oil Level Sensor_______2__Blue/ Green ***
    16_Brown/ Green__Oil Pressure Switch_____23_Brown/ Green
    17_Blue/ White___Diag. Connector pin#7___7__Black/ Violet
    18 & 19_________Not used_______________
    C104 Pin # & Color___Job___X20 Pin # & Color
    1__Black_______Engine Speed Input (Tach)__14_Black/ White
    2__Green_______??????????????
    3__Yellow +???___Econo Gauge____________24_White/ Black
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • shiboujin
    • Feb 2006
    • 2791
    I have a premade harness from a parts car that I had a while ago. I can sell you that one. No idea what it's worth but I know the guy that did the wiring and trust him. Never saw that parts car run though...
    • 2mAn
      Señior Mod
      • 20989
      Is it for an 84?
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      • shiboujin
        • Feb 2006
        • 2791
        Square plug. Not the normal C101 *shrugs*
        • 2mAn
          Señior Mod
          • 20989
          rectangular C101?
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • shiboujin
            • Feb 2006
            • 2791
            yea. I think it's called something other than a C101 in early eta cars. But yea, rectangle into the stock M50 harness X20.
            • 2mAn
              Señior Mod
              • 20989
              would prefer to do the wiring myself, but shoot me a PM about it. Anyone have some info to help out?
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • 328ijunkie
                • May 2007
                • 3961
                There's a reason I charge more for the m10 cars lol. Pita. :P
                Check Us out on Facebook
                Full Product Line Tuning
                • 2mAn
                  Señior Mod
                  • 20989
                  bump. mostly curious what I need to do for my oil level sensors since my M10 car didnt have the wiring going through the C101. I havent traced the wiring on my current motor to see where it goes, but I have a feeling these go through the C104, but havent found the info on the wiring diagram... getting close though
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • Jean
                    • 18228
                    It's still a c101, you just run the mpg/tach/check engine lights to the car and ignore the oil level sensor wires unless you want to add a check panel..... Cut the rectangular c101 off, install round one to match the engine harness, run the extra wires to inside the car/dash. Done.
