Motor been in for a bit. What would you retorque/check?
  • shiboujin
    • Feb 2006
    • 2791
    Basically, I'm paranoid as waffleswaffleswaffleswaffles. Too many bolts/fluids/issues to think about to get it done right in the first go. I've driven the car around for a good 20 miles and feel like it's a good time to get under it and make sure all the bolts are still there and nothing is uber leaking.
    Things I'm gonna retorque/check:
    Motor/trans mounts
    drive shaft bolts
    clutch fan (yep, managed to keep mine)
    intake mani
    What else? I figure things like the exhaust would have leaked by now. I also figure internal components or things like the oil pan would also have leaked but also might be more prone to leak if I get back at them. Hence why I'm leaving the head bolts be. They are ARPs anyway so I'd have to take the cams out. Maybe I should retorque the cam bolts... At one point in time, this motor was 100% apart minus bottom end rotating assembly.
  • M-technik-3
    • 18946
    You torqued them when you assembled it correct? If so your being paranoid as mentioned.
    • shiboujin
      • Feb 2006
      • 2791
      Anything internal engine, I torque with a torque wrench. Everything outside I torque to the "good and tight" spec lol. Realistically, yea, if it hasn't fallen off now, why would it? But I've seen cars where bolts slowly back out.
      • george graves
        • 20003
        Someone correct me if I'm wrong - but I think lug nuts are the only bolts that are spec'ed as needing checking after XXX many miles.
        Originally posted by Matt-B
        • M-technik-3
          • 18946
          Did you use new hardware or old? Old can back off if they were a locking type nut.
          • shiboujin
            • Feb 2006
            • 2791
            Some things were new, some were old. The drive shaft nuts are definitely old so that's why I'm retorquing those.
            • 7pilot
              • 475
              I would check the differential mounting bolt torque.
              m
              • shiboujin
                • Feb 2006
                • 2791
                Didn't touch the diff though.
                • FredK
                  • 14764
                  Spark plugs. I've never had them back out using my calibrated hand, until this one fateful day that one actually did back out.
                  Exhaust manifold nuts. These will require re-snugging after a heat cycle or two. The last thing you want is a leak at the head.
