Early Chassis 24V swap wiring????
  • JiXer
    • 620
    Working on an 02/87 325iS chassis and have not been able to find definitive info on a few things. Is there one thread out there that I am missing that has all the info?
    Specifically looking for:
    - C104 wiring
    - tach wiring
    - oil level sensor wiring
    - unloader relay wiring
    Any leads would be great, but I have a hard time believing there isnt a thread for this already?
    J. Farina
    Yeah, thats me kicking up all that dirt!
  • evandael
    • Oct 2009
    • 2881
    check http://www.wedophones.com/Manuals/BM...g%20Manual.pdf
    c104 is behind the glovebox. tach wiring comes from the c104 as well. oil level sensor goes through the c101 (two wires, low and 'sufficient'), unloader relay is easily found in the ETM.
    good luck!
    • JiXer
      • 620
      I know where the c104 is. I just cant find definitive info on which wire from the e36 harness goes to which wire on the c104. I have seen nothing but confusing information.
      Looks like the oil level sensor has to be run as a complete separate circuit I believe bc I am not finding that plug on the e36 harness at all? May be looking in the wrong place.
      Unloader relay is also not cut and dry. The older c101 does not have a separate pin for the black w/ green wire that goes directly to the starter.
      J. Farina
      • Regnar75
        • Sep 2011
        • 483
        Ask Dave markert. 328ijunkie on here. He specially makes and sells wiring harnesses for swaps but I'm sure if your determined to do it on your own he'd let you pick his brain on a few pins so you don't set your car on fire. Worth a shot but just understand he sells them so he may not be totally for revealing trickier aspects of it. But hey good luck. He is a nice guy regardless.
        • JiXer
          • 620
          I would never blindly plug a harness in without full disclosure as to how it was wired. Did that once with my first swap with a treehouse adapter. Melted the whole harness and nearly caught on fire. Hopefully he understands that :) and will help. Thanks for the tip.
          J. Farina
          • Wanganstyle
            • 2828
            go to BMW dealer:
            Get diagrams for both engine and chassis.
            Or
            find online in the ETK.
            Make your own spreadsheet for wiring = DONE.
            If you search hard enough you can find these and wire anything yourself.
            • JiXer
              • 620
              Appreciated, but I have all the wiring diagrams.
              That doesnt mean I know what wire goes to what.
              They arent all called the same thing and it isnt cut and dry to me as to what is going on.
              Otherwise I wouldnt ask. Really just looking for that thread where I am sure someone has been through this before. At least to confirm my hunches before I turn the key :)
              J. Farina
              • JiXer
                • 620
                bump... still looking for help here.
                J. Farina
                • Wanganstyle
                  • 2828
                  I believe you did NOT READ my statement; or had difficulty comprehending the logic behind it.......
                  Make your own spreadsheet and figure it out yourself from the wiring diagrams.
                  Google has a free spreadsheet product that you can use
                  • evandael
                    • Oct 2009
                    • 2881
                    i think what we have here is the curious instance of 'please use your free time to tell me exactly what to do'
                    its not rocket surgery, man. you can do it. spend the time, then come to us with specific questions. i guarantee it'll be a more congenial atmosphere.
                    • JiXer
                      • 620
                      On the unloader realy.... is it safe to assume that You can splice the Blk/Grn wire that goes to the starter directly to the Blk/Ylw starter wire? the early 101 did not have a separate pin for Those two wires.
                      Also, it seems that there are 2 tach signals going through the x20 connector, Pin 14 which is Blk/Blu and Pin 20 which is solid black. I believe pin 14 is supposed to connect to c104 and from what I can tell, pin 20 must connect directly to the cluster, but I don't know why there are 2 wires that seem to serve the same function as the black wire on the c104 also goes to the cluster.
                      Can anyone confirm this?
                      J. Farina
                      • 2mAn
                        Señior Mod
                        • 21017
                        this might help you
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • jclar
                          • 265
                          Pin 20 to C104 and pin 14 to the back of the cluster, iirc.
                          EDIT:
                          Also wondering about unloader relay wiring, haven't been able to find a definitive answer.
                          '86 325es M50
                          • e30rapidic
                            • 2167
                            I have an S50 in my 10/86 build e30....and have the stuff below in my notes.
                            pin 24 goes to the white/yellow wire of the c104 (Econo Gauge)
                            pin 14 goes to the black wire of the c104 (Tach)
                            I don't have info for the unloader relay, doesn't go through my harness.
                            e36 harness does not have the oil level sensor plug/wiring, that's the e34.
                            '87 325ic, powered by S50.
                            • 2mAn
                              Señior Mod
                              • 21017
                              thats great news right there! I almost have all of my wiring figured out now. I have a E34 harness and plan on hooking up the oil temp to an external VDO gauge. thanks for helping
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
