The OFFICIAL 24v Engine Bay Thread
This is a sticky topic.
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    #121
    there shouldn't be a problem since it's just the expansion take which doens't take much pressure. i've checked the system and it's working properly, it's really not that bad in person i felt the hose after the engine heated up and drove around the neighborhood a few times, all is fine. I guess i can always wrap it in some insulation. I'm trying something different, i guess it could blow up in my face or work just fine, not like took off my front brakes to drift better;)
    • Rev Engineer
      • Jan 2006
      • 162
      #122
      I removed my e30 m3 tank and put in a "i" tank. There's no room to run a hose behind the engine. I'm tempted to do what Tony did, but the "i" tank works nicely once you get it mounted.
      • tjhartge
        • Jun 2004
        • 86
        #123
        You could use an S14/M3 expansion tank and some hoses. I believe they are routed behind the engine.
        i have seen on another car, i can't recall which model, that had a metal tube that resembled the coolant hose that's mounted across the lower part of the radiator, think this would be a safer bet rather then having the coolant hose running for a very long length
        i believe the expansion tank should be at a higher level compared to the engine as this will ease/help coolant flow and pressure
        anyone care to input?
        tony
        please check if your expansion tank is releasing excessive coolant after engine is cooled down
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          #124
          coolant level is a bit higher when car is warmed up but nothing to be alarmed about, I'll take better pictures tomorrow, it just the angle it was taken at.
          • ///Mpressive
            • Mar 2006
            • 192
            #125
            I have a few things to sort out, but it drives fine for now. I am looking forward to connecting the rest and cleaning up the engine bay a little (wires and such). I am going to make some brackets for a few things soon as well. I am very happy with it so far. :)
            08 Toyota FJ Cruiser, Rock Sliders, Mostly Stock for now, parts on the way....
            97 Toyota Land Cruiser FZJ-80, Front Bambi Basher w/ 2x100w PIAA's, mostly stock
            • tonytony
              Knee deep in poopie
              • Jan 2004
              • 3498
              #126
              looks greasy, but nice:up:
              • static
                • Oct 2005
                • 501
                #127
                ///Mpressive, noticed you don't run the mechanical fan. Do you just run stock aux fan? or you have bigger electrical fan in front?
                • ///Mpressive
                  • Mar 2006
                  • 192
                  #128
                  Currently not running a fan. I am on the look out for one though. I am not 100% on what I'm going with either.
                  • KangamangusDriver
                    • Aug 2005
                    • 1870
                    #129
                    Mrpessive:
                    OBD1 or OBD2 assuming that is the 3.2 litre
                    If obd1 how was the conversion? Run into any difficulties?
                    • matt
                      • 3731
                      #130
                      It's OBDI. The conversion isn't hard. The motor fired up first try.
                      • BDSax
                        Junkyard King
                        • Mar 2006
                        • 3593
                        #131
                        wow, i like that air filter setup //mpressive! where did you get it?
                        NEED SOME VINYL STICKERS???
                        • ///Mpressive
                          • Mar 2006
                          • 192
                          #132
                          Thanks. I made it from some piping that I bought. I cut it to size and added a cone type filter. Total spent - $35.
                          What you can't see is an 5 inch intake airhole under the filter that pushes cool air directly into the filter.
                          • 1990m3
                            • 1180
                            #133
                            What you can't see is an 5 inch intake airhole under the filter that pushes cool air directly into the filter. Pics soon..
                            I bet that intake setup makes a nice noise! I bet it's quite torquey too.
                            • Mike B.
                              • Jan 2006
                              • 987
                              #134
                              Intakes are so much easier to plumb without that pesky ABS pump. Has anybody tried to relocate it?
                              • Jason89i
                                • Sep 2004
                                • 875
                                #135
                                i did see a racecar with the abs pump in the battery tray. i will look for pics. the only difficulty is finding a flaired end tool that does the bmw "bubble" end fittings. jason
