I know sound questions are hard to diagnose over the internet but any help is appreciated--the noise is pretty easy to hear on the vidoes below.
I'm getting a loud howling at WOT between ~5-6k rpm. It's noticeable on the street some, at the track (including the videos), and I just did an autocross event where you can really hear it. FYI, the mic is at the rear bumper.
Seems to be mostly second gear, it goes away after 6k rpm. The check engine light comes on sometimes for 1 or 2 seconds.
Otherwise, car pulls really well, sounds good, and runs smoothly.
**excuse the noob autocross driving**
I've heard that the TRM chips sometimes cause check lights at the higher rpms depending on the exact 3.5" MAF you use, although, I did send them the part number when I was getting my chip. No one mentioned any noise associated with the check light.
Waterpump is new, tensioner is new, belt is new. no AC, no PS, no idler pulley. Ka motors 3.5" intake
Could it be intake noise? Why the check light?
A vacuum leak?
harmonic balance problem?
Ping from my higher compression pistons?
Something with the exhaust?
Details on the car:
rebuilt 1995 M3 S50B30US head on a rebuild and overbored 1999 M3 S52B32US block 11:1 CP Pistons, 21.5# injectors, Turner underdrive pulleys, TRM chip, AC+PS deleted on AKG solid aluminum motor mounts.
Driveline: Stock g260 with 3.73 LSD.
Exhaust: Ebay Supersprint replica header to Magnaflow "y" collector to single Vibrant 2-1/2 High Flow Cat to Vibrant 2-1/2 Ultra Quiet Resonator to Vibrant Streetpower muffler.
A vacuum leak?
Details on the car:
