G260 preparedness for swap
  • Wanganstyle
    • 2828
    Originally posted by Ian Bowers
    Why swap an E30 when you can buy an E36? Faster, safer, blah blah blah.
    why buy e36 when you can buy a e46 or e92? blah blah blah heavier, bigger, more vip
    • golde30
      • 11464
      I recently finished building another s52 obd1 e30, with ZF tranny and 3.25lsd rear end. Lined it up with my s52 obd1 e30 with getrag260 and 3.73lsd and the ZF e30 pulled on me in every gear. Not only that but my car has bolt on mods and an s52 with waaaaay less miles. ZF is the way to go.
      However I will say that my 200k+ drivetrain has held up for over 20k miles no problem, and I beat on it pretty hard. Also I prefer the notchy feel of thr getrag, the positive engagement feel into every gear is nicer than thr vague feel of the ZF. That said I am still going to swap over to ZF just for the performance.
      IG: @Baye30
      • DesertBMW
        • Aug 2011
        • 1031
        I find the later model 97-05 getrag 250 to be a good lightweight transmission. Because E30 is much lighter than E36 and E46, I find this transmission to be very good and holds S52 no problem.
        • Wanganstyle
          • 2828
          drive shafts for it are very common also; from 323/325 e36 all day long almost free if you ask friends.
          one could probably profit if selling off the G260+its driveshaft and going to a E36 G250+g250 driveshaft with correct tilt/shifter linkage to plug and play with e30 24V
          • amcink
            • 788
            Wagan would you please expand on the plug and play; if i found a transmission g250 and its drive shaft to install on my M50 it is jsut plug and play?
            The transmission it is $129 at pick n pull and about $50 for the drive train. how about the diff; can i use my E30 one (2.93 I believe)
            • Wanganstyle
              • 2828
              G250 transmission is oem factory bmw attached to m50 engine.......
              For any 24v engine you can use any 24v gearbox with its matching e36 driveshaft
              Zf sg310 and 320 5 speed is with s50/ s52/m52
              G250 5 speed is with m50 from e36 325 and 323i.
              The g250 and e36 325 driveshaft fit a e30 perfectly just like a zfsg320 and e36 328i
              Driveshaft. Get the shift linkage/driveshaft/gearbox all at once.
              e30 center bearing is fitted to the e36 driveshaft to match e30 body.
              328i is as common as 325 or 323 in the scrapyards
              Same concept; much more common parts. All oem and avail CHEAP
              Sent from my GT-N7100 using Tapatalk 2
              • amcink
                • 788
                Wangan - is this want you meant? (see attachment)
                • Wanganstyle
                  • 2828
                  uh-huh. this is what everyone does when fitting e36 driveshaft on E30 as the center bearing standards are different.
                  I used a e30 center bearing + e36M automatic driveshaft for my e46320D euro 6 speed conversion
                  • amcink
                    • 788
                    Thanks- I will start my hunt and wait for the pick n pull 50% special.
                    • amcink
                      • 788
                      OK pick n pull special this weekend G250+drivetrain for about $110 bucks due to the 50% memorial day - there are some ZFSG320 + drive train but not on special at the Premier side and it cost about $460. Therefore I'm getting grease this weekend and pulling the G250 and drive train; shift linkage and clutch
                      Thanks everyone for their input
                      • 10Toes
                        Me Father Was A Tree
                        • Jan 2008
                        • 61222
                        What type of maintenance I need to do to the G 260 prior installing onto the M50 swap?
                        Cut out two holes so that you can access the rear oil pan bolts.
                        • Balleristic31
                          • Aug 2009
                          • 4198
                          Do you use just the front half of the driveshaft or the entire shaft?
                          -NICK
                          • amcink
                            • 788
                            The entire shaft is what I will get and understand that is need it
                            • emmanuel.dlc
                              • Jun 2011
                              • 144
                              this, i did it!
                              Sent from my Nexus 10 using Tapatalk 2
                              • amcink
                                • 788
                                Ok got the G250 from a 95, will my m20 derive shaft work with this or do y need the e36 driveshaft. Also how about my M20 clutch and single mass flywheel can I use this with the G250?
