Instrument Cluster ?
  • jwiles
    • Jun 2012
    • 200
    Which Instrument Cluster Are you suppose to use if your doing the S52 swap or for that matter any 24v swap into a 1986 325e?
    hell idk sometimes you just have to wing it. JW
  • Poorboyz
    • May 2012
    • 2117
    Use an i cluster I believe with the 7k tach
    Sent from my Galaxy Nexus using Tapatalk 2
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • Aviator
      • 616
      I think my scenario is fffffed because of my ancient e30. Someone said here that you're screwed if you have an 84 or 85 because the old clusters can't be swapped. Is this correct? Mine is junk and I wanted to replace it with a newer I cluster for the M50 swap but I guess it won't work?
      84 325e Burgundrot S52 M Tech 1.
      http://www.r3vlimited.com/board/showthread.php?t=250109
      • jwiles
        • Jun 2012
        • 200
        Do you know if there are any write ups for that swap.
        • jwiles
          • Jun 2012
          • 200
          In the read this thread and the wiki write up they never mention the instrument swap. I don't see how the 84 or 85 wouldnt work
          • DesertBMW
            • Aug 2011
            • 1043
            I run VDO 7000rpm cluster from 1989 325i into my 5000rpm 325e, it works fine, it is plug and play, fuel gauge reads correctly.
            • jwiles
              • Jun 2012
              • 200
              thanks
