E-30 build HELP installing a E-36 swap m50
  • Sharkii
    • 18
    WOW MY BAD!!! MUST OF HAD A BAD DAY HAHAHA,
    ok so i need some info, i have a m50 motor going into a e30 and im rebuilding the motor.im just about to take it to machine shop to get it worked on and then i need to have my friend assemble it, but he needs some info that hes not to sure about, im trying to put a turbo on this motor nothing to crazy maybe like 5-10 pnds of boots. i bought A thicker head gasket to lower the compression and since im using a bigger head gasket will the oem spec timing chain with the low comp. head gasket work?.and also if we need a different chain, do we need new gears as well?. if so what kind of chain and gears and from where should we get them.?
  • Poorboyz
    • May 2012
    • 2117
    I can't read this thread, maybe some punctuation would help.
    GL
    Sent from my Galaxy Nexus using Tapatalk 4
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • gtdragon980
      • Jun 2008
      • 1808
      I seriously cannot comprehend a thing, even if I imagined the punctuation!!
      FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
      Originally posted by scabzzzz
      I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
      1989 325i - Project/weekend driver
      2002 325i - DD
      2005 Suzuki SV650 - Toy
      • Silverdogz
        • Aug 2012
        • 168
        Originally posted by Sharkii
        Ok so I need some info.
        I own an m50 motor that is going into an e30 and I've rebuilt the motor. I'm just about to take it to machine shop to get it worked on and I need to have my friend assemble it but he needs some info that he's not to sure about. I'm trying to put a turbo on this motor, nothing too crazy, about 5-10 lbs of boost. I bought a thick head gasket for lowering compression and since I'm using a bigger head gasket will the OEM spec. timing chain with low compression head gasket work? If not where should I get a timing chain and as well as gears?
        GL
        Better?
        so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
        • slammin.e28
          שמע ישראל
          • 12054
          Something about needing a new timing chain for a thicker headgasket?
          No. There is slack in the chain that the tensioner takes up. The tensioner will just have less clack to take up. You'll be fine.
          • Thizzelle
            • 4422
            Slammin FTW
            "I wanna see da boat movie"
            "I got a tree on my house"
            • Nick_S
              • Apr 2011
              • 3656
              Be careful not run to many boots, you could pope a tire.
              91 318is M50 swapped
              05 Honda Pilot
              24V swap thread
