24v harness adapters - group buy thread posted!!
    • 34844
    I do personally prefer a re-pinned harness, but some people want adapters and it seems like nobody is making them (or at least, not at prices that make sense). I don't want to work on old, dirty harnesses anymore so if you want a re-pinned harness, talk to dave (328ijunkie).
    I could be persuaded to make a batch of adapters - something like 10 - if there's enough demand and it's kept simple.
    it would be for:
    Round C101 cars
    OBD1 harnesses
    Early cars with the connector in the glovebox and the oil level sensor wiring would be extra (more parts, more work, more R&D).
    Basic adapter (just C101 to X20): $175 (shipping included)
    add oil level sensor: $25
    add connector in glove box for early cars: $25
    Here's an example of the adapters I'd build:
    All new wires, pins, connectors, & boots:
    professionally crimped:
    Approximately 6" long. This one I used high grade electrical tape for sealing but I'd probably use some shrink wrap instead with braided wire covers.
    I could also leave a labeled pigtail for the glovebox connection/oil level sensor if you want to hook that up yourself, instead of charging extra.
    Any interest?
  • Nick_S
    • Apr 2011
    • 3658
    You already know I'm interested.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • nokincy
      • Feb 2012
      • 302
      I would buy an OBD2 one.
        • 34844
        OBD2 requires a splice into X6031 if you want VSS etc (which you do).
        I could provide a pigtail, but you'd have to hook that part up yourself. I could look into a plug in solution but it'd be more wires, and usually with an OBD2 harness I'd cut that connector off and re-route the signals through the harness to the C101.
        • kid325e
          • Sep 2007
          • 6422
          Would potentially be in for one of these..
          clutchCTRL!
          Move with a purpose.
          - 1991 325iX 4dr/5spd
          - 2000 323i AT
          2016 Mazda CX3 Sport AWD
          • nrubenstein
            • 3148
            IMHO, adapters are much better than hacking up your harness. Why would you not want the standard wiring diagrams to make sense? And these are nice pieces - not making all the wires the same color is such a weird concept. :p
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • nokincy
              • Feb 2012
              • 302
              A pigtail would suffice if you decide to go this route.
                • 34844
                I actually try to make the colors match BMW wire colors within reason - but of course BMW wires are really expensive new, and I don't want to use old junk wires. It's too hard to get consistency, plus I don't always have every color/gage I need in my giant collection of old wiring harnesses.
                These wires are high grade, made in Japan. Actually, I originally bought them right after the Fukushima disaster. Shipping was delayed for months because US customs had to scan them for radioactivity. Heh.
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  Been doing a lot of reading in the ETMs.
                  IIRC for an OBD2 adapter you would just need to route VSS pin on the C101 to Pin 9 on the X20.
                  • justin_l_
                    • Jun 2007
                    • 1079
                    That is the input for abs asc correct? Does the ecu control the asc?
                      • 34844
                      yeah, I looked at my notes, it's the CEL signal that goes through the x6031.
                      so guys without a CEL don't need the x6031
                        • 34844
                        • RobertK
                          • Jun 2005
                          • 5864
                          Pin 15 on the OBD2 MS41.1 is the speed signal input (VSS) coming from ABS/ASC from the right rear wheel sensor on an E36. Which is basically the VSS input. Instead of getting vehicle speed from the cluster speedo / diff speed sensor OBD2 cars get VSS from the ABS wheel speed sensor after its passed on by the ABS/ASC module.
                          (Still new to sorting through these ETMs so someone please correct me if that's wrong or a bad interpretation.)
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Correct. its a little different than the obd1/e30 one.it being a 48 Tooth pulse wheel Signal vs 9.
                            Thus the ecu thinks you're going really slow all the time. ~1/5.33 of what you're really doing iirc
                            Check Us out on Facebook
                            Full Product Line Tuning
                              • 34844
                              nobody has found the K-factor in MS41.1? should be a 2 byte value, somewhere in the 20,000 range (pulses per KM).
                              all you have to do is change this value to pulses per KM for a 9-tooth wheel. then the VSS input from an E30 will work fine.
