E30 s50 swap won't start please help
  • bmwdready347
    • Jan 2011
    • 586
    Hey guys I recently put a 1995 m3 motor in my 1992 e30 convertable every thing is done just. Can't get it to run .. I'm using a tree house racing adapter so wiring shouldn't be an issue tested in a friends car and it worked .. I started car with quick start and I had to jump a power wire to starter to start car .. Once I guess whatever quick start was finished it would shut of ..can some please help thanks
  • DesertBMW
    • Aug 2011
    • 1042
    You are not getting power from the ignition switch to the starter "RUN" post. Check and see why, is it because of the bad wiring, bad clutch switch?
    Also looks like injectors are not delivering fuel, but ignition coils are able to run the engine while the starter fluid is present. Check fuel pressure delivery. Lift the injectors out of the intake manifold, check and see if they are all working.
    • bmwdready347
      • Jan 2011
      • 586
      Thank I will check these thing tommoro ..... Again thanks
      • bmwdready347
        • Jan 2011
        • 586
        I got car to start and run but not with key.i have to send power to the fuel pump wire and send power to starter wire .i am not getting no signal when I turn key on to start......help help please
        • NickL
          • 562
          Go through your C101. Just because it worked in a friends car doesn't mean it will work in yours.
          1987 325is - S52
          • bimmerteck
            • 762
            If you paid treehouse for an m50 adaptor call and get them to sort it out.
            615-333-9118
            If you bought it used it's sounds like it's not correct for your car, so you'll need research the ETMs for both your chassis and the donor motor to re-pin it for your car.
            • bmwdready347
              • Jan 2011
              • 586
              Thanks guys got it working
              • 1e30ftw1
                • 3
                what was the fix?
                • bmwdready347
                  • Jan 2011
                  • 586
                  Starting issue
                  Removed the adapter and wired it my self started rt up
                  • JCarp90
                    • Feb 2011
                    • 1759
                    Did that adapter not delete EWS?
