Long post here and thanks in advance for those of you who take time to read it and respond. I recently swapped an S52 into my 95 E34 Touring. This forum has a lot more S52 swap expertise than any of the E34 forums so I thought I would try looking for info here. I purchased the engine from a fairly well respected salvage yard a couple of years ago and it sat in my garage when health problems forced me to delay the swap. It supposedly only had 90K miles on it at time of sale. There is no warranty coverage now but I accept that it is my problem because I waited too long to install it and am not complaining about the seller. I got the engine running well in April but had repeated difficulty getting it to pass emissions for HC at idle in NJ. That was with new plugs, good coils, cleaned injectors, all new intake gaskets and hoses. I don't know if the emissions failures were any kind of precursor to what happened.
At my last try to pass emissions, the engine failed while waiting in line on a very hot day. I shut it down as I pulled into the state inspection garage because that is the procedure. I think they make you sit long enough for the cats to cool before testing. When I restarted, the engine immediately started misfiring and running very rough. It had been running and idling beautifully prior to this. I pulled it out of the building on something like 3-4 cylinders and parked it to wait for a tow. I noticed loud crunching noises and knew there was metal on metal contact but had to get the car out of there. No one was going to help me push it out on a 90 degree, humid day. Here is what I know so far:
Zero compression in cylinder 1 and I can see the piston is clearly cracked with a fiber optic inspection camera. Cylinder #1 seems coated with wet paste-like layer of aluminum and I assume this is because something was getting smashed repeatedly before I could shut down. The piston still goes up and down with the connecting rod when I turn the engine over by hand. It turns over freely by hand. I did not see any obvious foreign object in the cylinder with the inspection camera and was not able to get a good image of the valves. Something was smashed in there but I don't know what yet.
180-195 psi in the other cylinders but it was definitely misfiring on more than just #1. I know what this feels like with only one cylinder out and this was worse.
A/C compressor belt was new and is worn severely on both outer edges almost like the crankshaft was moving in and out. When A/C was on, there was always noticeable shaking from the engine that stopped as soon as I turned A/C off. I used it as little as possible because of that but had run it for about 10 minutes while waiting in line to cool the car interior down. I figured it was a bad compressor and did not imagine the problem was more than that until the failure. I can't detect any axial movement of A/C compressor from a quick inspection and the crankshaft does not move axially with engine off when I push and pull on the harmonic damper/pulley assembly. I didn't expect it to but tried anyway. The main serpentine belt does not show any unusual wear.
I am going to pull the engine, put it on a stand and tear it down to try to understand what happened and why. My questions are for experts out there that have dealt with S52 failures before:
1. Does this engine have any known problems with dropping valves due to valve keeper failure? I thought only some of the early S50 engines had this problem.
2. Are there any known S52 issues with the crankshaft developing axial play that could have caused this? (Crank 'walk')
3. Are there any known issues with bad A/C compressor contributing to engine failure due to vibration?
4. I searched for information on crankshaft 'walk' but did not find much useful. Are there any web pages or threads that have useful information that I may have missed in my search?
5. When I tear down the engine, are there any tips or suggestions of what to look for? I will document what I find with pictures and post here if there is sufficient interest.
