e30 m52b28 swap..Driveshaft questions..??
  • e30forlife
    • Mar 2012
    • 583
    I am doing a swap on my 91 318i.
    Engine is out of a 328i and im using a g220 for my transmission. Im running a 3.73 diff in the back.. I thought a 325i driveshaft would work from what ive read? I measured from flange to flange and looks like im getting 59 inches give or take 1/4 inch..
    The driveshaft I have came out of a 99 323is..Measures right at 59 inches. i dont have enough room for flex disc.
    which driveshaft should i use? or am i missing something?
    91 318 s52 Swap
    -m50 manifold
    -headers
    -zf320
    -3.25lsd
    -KaMotors Intake
  • DesertBMW
    • Aug 2011
    • 1040
    Getrag 220 is same as 250, looks like. So you may have 318i driveshaft, it will fit 323i but it will be too long for E30.
    I got everything from 1995 325i and driveshaft barely has some slack, like 1/4 inch
    You may get away with it, if you don't use that dust nut
    • e30forlife
      • Mar 2012
      • 583
      What do you mean I may have a 318i driveshaft? Thats what came out of the car before I did the swap...So I have a 318i driveshaft and a 99 323is driveshaft.
      They both are too big from what I can tell. Anyone know what would fit for a 59inch gap between flange to flange??
      Any help is much appreciated..The drive shaft and wiring is all I have left for the swap.
      91 318 s52 Swap
      -m50 manifold
      -headers
      -zf320
      -3.25lsd
      -KaMotors Intake
      • e30forlife
        • Mar 2012
        • 583
        Anybody got any ideas? Do I need to start measuring drive shafts to figure out my options? or am I missing something?
        91 318 s52 Swap
        -m50 manifold
        -headers
        -zf320
        -3.25lsd
        -KaMotors Intake
        • DesertBMW
          • Aug 2011
          • 1040
          What is the part number on the driveshaft that is on the white sticker?
          • e30forlife
            • Mar 2012
            • 583
            just checked..No serial number or anything..my buddy said he pulled it from a 99 323is.
            91 318 s52 Swap
            -m50 manifold
            -headers
            -zf320
            -3.25lsd
            -KaMotors Intake
            • DesertBMW
              • Aug 2011
              • 1040
              Well that's the problem. Measure it, totally compressed from one flange to the other, whats the exact measurement in metric?
              • e30forlife
                • Mar 2012
                • 583
                Ok So I swapped back in my g240 transmission. My original 318 driveshaft wont even fit. Im like 2 inches to long.. What gives? I finally got the car cranked last night but cant drive the damn thing..
                I see everyone basically using e36 manual drive shafts or even e30.. I almost need like an automatic drive shaft.
                Any input would be appreciated!!
                91 318 s52 Swap
                -m50 manifold
                -headers
                -zf320
                -3.25lsd
                -KaMotors Intake
