s50 swap in 84 318i
  • 5150ct
    • 79
    s50 swap in 84 318i
    piecing together my swap, what is the best master cylinder to run and what booster? Im looking for bolt in and am not to crazy about slotting the firewall. My brake master went out am currently DD the car so now is as good a time as any to change the booster and master. thanks in advance for the help.
  • 5150ct
    • 79
    Im running the E36 M3 5spd. What drive shaft should i run? i have the E36 shaft and the stock shaft 318i. gonna run the diff out of an E34 535i
    • 2mAn
      Señior Mod
      • 20783
      Im in the middle of my swap now and I went with a iX booster because I didnt want to deal with slotting/ rethreading, etc, but because we dont have ABS (mine is also an 84 318 it might be easier to just use the stock stuff and slot the holes and modify the clevis.
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • 5150ct
        • 79
        what master cylinder should i run?
        • 2mAn
          Señior Mod
          • 20783
          This is personal preference. I didnt want to deal with modifying the firewall, modifying the clvis, etc so I used an iX booster and master and we are "T"ing the two front brake lines into one. Basically your only other option is to run the stock booster and master and slot the firewall, and modify the clevis. your call
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          • 5150ct
            • 79
            what about the e32 735i booster and master with the 2002ti remote reservoir? heard theyre a direct bolt in aswell.
            • butters
              • 1202
              They are.. you might try researching the forums
              • 2mAn
                Señior Mod
                • 20783
                spend a LOT of time researching. 84s are a different beast alltogether. I thought I had most of it figured out and its been one thing after another.
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
