Hey guys!
I'm having a bit of an issue sorting out the finishing touches on my e30 swap.
when cranking the car I get spark, however the fuel pump never primes or pumps and the injectors don't pulse.
I can manually relay/jump the fuel pump and get fuel to squirt out my lines and verify they are hooked up in the correct direction but when I hooked a scope up to the injectors I get no pulse.
Relevant specs:
87 325e
OBD1 harness from a 94 325is mtx car
OBD1 red lable 413 DME
TRM OBD1 S52 Chip
Wire 66 clipped at ecu to disable drive away signal.
S52 from a 97 m3 atx
obd1 intake manifold
obd1 sensors
brand new oem obd1 crank position sensor (scoped and verified it sends signal when cranking car)
I'm pretty stuck on this, originally I thought I was having the dreaded no start due to bad CPS however a new and verified good crank sensor didn't fix the issue and now I'm really running out of ideas.
Any help is greatly appreciated!
Thanks in advance,
Brad
Relevant specs:
87 325e
TRM OBD1 S52 Chip
obd1 sensors
Thanks in advance,
Brad
