HELP--Throwing MAF and air intake temp codes
  • Widebody325
    • 417
    I have just swapped a Vanos M50 into my E30. The car runs, but its in limp mode. I borrowed a Bav Auto code reader from my buddy, and it turns out I am throwing a 4b and a 28. Which is Air Intake temp and Mass Airflow Sensor. My engine harness did not come with a MAF plug, so before I got one I had wired it up that way I thought was correct. If I had wired it incorrectly could have that fried my MAF. Could the MAF have been bad to begin with? Is there anything I can do to test it to see if its any good? I dont really want to buy one if I dont have to. Any help would be greatly appreciated. Thanks again, Ben
    Follow me @baysidefabrication on Instagram
  • Skafrog
    • 1732
    Air intake temp is the connector on the underside of the intake manifold, near the back of the motor.
    Yes, you could have fucked the MAF up. The e36 bentley has procedures for testing it (make sure you dont use the non-vanos procedures).
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
    • Widebody325
      • 417
      hmm, I will have to check that sensor under the manifold. I know I have another one, but maby the wrong plug?
      • Skafrog
        • 1732
        Maybe, its two wires, grey and brown.
        However, you need to be worrying about your MAF, as that's the main problem.
        EDIT: You need to get yourself a bentley and pour over the wiring diagrams, and also get a pin-out for the MAF.
        • Widebody325
          • 417
          I have a Bentley. I just didnt know what pins were what before I sourced down a plug, and like a idiot I probably put the wrong wires to the wrong pins. Now with the plug I have everything wired correctly. So im leaning towards fried MAF.
