Tried searching with no luck, I have an m50nv that is idling erraticaly like the video from this post:
Unplugging the CPS cause no obvious change in idle and the resistance is 1334 ohms. Anyone know if this is good? The post above says that a good sensor should be around 1400 ohms. Can anyone confirm this? Does anyone have a good one that they would mind testing real quick?
Thanks!
Thanks!
