m20b25 S-52 crank stroker
  • dwight
    • Dec 2012
    • 550
    Hi guy's
    I'm using a s-52 crank in my m20b25 stroker build and need to know if I can use my m20 harmonic balancer or do I need to use the s-52 one?
    Thanks for your kind help
    Dwight
  • dwight
    • Dec 2012
    • 550
    Up
    • digger
      • Nov 2005
      • 6140
      maybe if you posted in M20 section you would get a better response?
      M20 vibration damper is what is used in anycase
      • dwight
        • Dec 2012
        • 550
        Thanks Digger
        Thanks Digger one less item to buy.
        Dwight
        • Nutzy
          • Sep 2011
          • 102
          Diggs, are you using the a stock BMW damper? New, or used? You have the 89mm crank, so harmonics must be a concern?
          89 M50B28 turbo
          LINKY
