Pesky s52 OBD2 codes
  • ClausE30
    • Sep 2011
    • 981
    Hey guys, I'm currently trying to figure out and research my pesky s52 obd2 problems..
    Found these codes:
    P1519
    -So I replaced the vanos (dr.vanos) and camshaft sensor and I still got the P1519 error code again..
    P0170 (Fuel Trim)
    -vac leaks?
    P0304,5,6 (Misfires in cylinders)
    -When I let off the throttle and decelerate, the car does "backfire" by making some popping sounds out the exhaust. I believe this to trigger the misfire codes? I noticed that the O2 sensor doesnt fluctuate in voltage, is this the cause? I did replace 1 of the 2 sensors recently.. Any other things to check?
    Any tips or pointers would help! thanks guys
    91 Alpinweiss2 318is OBD2 S52
  • plain325
    • Mar 2004
    • 163
    Did you send your DME to TRM for a flash?
    • ForcedFirebird
      • Feb 2007
      • 8300
      Cam timing is spot on?
      john@m20guru.com
      Links:
      • bimmerteck
        • 762
        What do the fuel trim values look like?
        • DesertBMW
          • Aug 2011
          • 1043
          When did the codes start poping up? Did you do anything to the engine before the codes?
          • ClausE30
            • Sep 2011
            • 981
            -Yes, Dave at markert motor works I believe sends his there to get tuned.
            -When reinstalled vanos I made sure to double check the timing was all correct
            -I hooked up my scanner that i can see on my iphone. either it is not giving my trim values or they all stay at 0%..
            -I noticed that the 1519 code came up as pending code, the misfire codes i believe came on while driving. Fuel trim might of been a pending one as well.
            -The 1519 led me to believe i needed to replace the cam sensor or vanos, so i did both..
            • JohnyEndo
              • Aug 2009
              • 64
              Make sure the vanos isnt plugged into a knock sensor
              • DesertBMW
                • Aug 2011
                • 1043
                Ok so you drove the car for a year then all of the sudden the codes started popping up after one year of trouble free running?
                • ClausE30
                  • Sep 2011
                  • 981
                  Nope I have barely put any miles on the car., for some reason my cel wasn't working after I "finished" the swap.. So I hooked up a scanner and got some codes
                  Ill make sure to check that later, the harness was pre labeled when I received it. Do they have similar electrical plugs?
