Extended o2 sensors
  • ClausE30
    • Sep 2011
    • 981
    Extended o2 sensors
    Where can I purchase longer wire o2 sensors? Can I extend a o2 sensor with wires and crimps or solder. I know the resistance would be altered due to longer wire but could that be a noticeable difference? Reason is one of o2 bungs is farther down the exhaust :/
    -thanks
    91 Alpinweiss2 318is OBD2 S52
  • Boise
    • 212
    I spliced one of mine to make it longer, used the sensor and wire from one and the plug and wire from another. I think the impact on resistance would be very minimal as long as you had a good connection at the splice. So far no problems.
    • butters
      • 1206
      Keep in mind the sensor needs to be hot to work properly. If for no other reason, I wouldn't want to extend beyond the intended design length because the temperature will drop off as you go farther back.
      I've only heard that you cannot do anything to splice into the wiring because it will affect the reading too much. Rather than deal with that, I'd cap the bung and have another installed within reach.
