Everything you wanted to know about brake boosters and master cylinders
Stock booster?
I have noticed in reading this forum, AKG and Zionsville that it seems to be common practice to replace the e30 brake booster with an e21 or iX/e32 model booster. Is there any advantage to doing this besides fitment?
I currently have my S52 (without driveline) test mounted up in the engine bay of my 87 325i convertible. With everything (manifold, t-body/boot) in place it would appear that the stock booster might work. I am using e28 M5 mounts with a half inch spacer on the driver side only. There appears to be almost a half inch of clearance between the manifold and the booster. If I shave the bottom portion of some of the manifold fins it would be almost 3/4" of an inch. I will also need to put the hood back on to check the height. I have attached some pictures below, keep in mind that the tranny is not mounted so the pitch angle may not be exact.
My question for those of you already running this swap is - how much does the the engine move around? Does the manifold expand much when it heats up? If a half to 3/4 inch is enough clearance then I would much prefer to keep the stock setup as I am reasonably pleased with my brakes.
Thoughts? :up: :down:
1987 325i Cabrio - SOLD
2014 Chevy Volt
2007 FJ CruiserComment
I really don't see why that's necessary, as the ix is an E30 and that setup should stop it just fine. I'm going to run a remote reservoir system to help the intake boot clearance issue. From what I can tell people like the E34 M5 MC because it's bigger and has a firmer pedal feel. I like the way it is now, and I figure with the ix MC it should be about the same. I have Zimmerman rotors and Porterfield semi race pads, so I really don't need major mods to my stops.1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing PadsComment
I'm also running E28 mounts. I'm not spacing anything, however, I'm just mounting it in straight, like AKG. I bet that half inch spacer is where you're getting your clearance from...I have noticed in reading this forum, AKG and Zionsville that it seems to be common practice to replace the e30 brake booster with an e21 or iX/e32 model booster. Is there any advantage to doing this besides fitment?
Clearly.
He will have issues when he goes to mount the downpipe. These motors need a small spacer on the exhaust side of the motor.Comment
Haha, that's what I said. If I think the pedal feels sloppy I'll definitely change it out, but I don't really like the idea of a more rearward brake bias in a car that is going to have torque up the yin yang and short gearing. I can damn near kill myself as it is with the M20b25 in there. It's not like understeer is an issue, even with the stock suspension on the car. It's a fucking dart man. Point and shoot.1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing PadsComment
Haha, I was planning on putting the car up on ramps for most of the swap anyway, since I won't need to take off the wheels until it comes time to replace the brake fluid and bleed the brakes, which is after I bleed the MC.1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing PadsComment
