This is probably a stupid question but is the e39 528i zf the same as the e36 328i zf? I found a pretty good deal on a 100k 2000 528i trans. and just want to make sure it bolts up the same at the e36 unit. Thanks.
e39 zf trans.
Tags: None
e39, e36, e46 all use the same zf sg320 5 speed unit.
newest would be from a e46 330i 2003-4OBD1 M54/M52TU swap as a M50b25
1985 325e M50TU(Sold)
1991 318is Slicktop (Sold)
1990 325is Brilliantrot S50/5 Lug Swapped.
1992 525i Manual shitbox Winter BeaterComment
If you look up the bmw oem specifications you will be able to see the individual gear ratios of the zf sg320 gearbox.
Above text answers your question
Sent from my SAMSUNG-SGH-I337 using TapatalkLast edited by Wanganstyle; 12-14-2013, 05:56 AM.OBD1 M54/M52TU swap as a M50b25
