Bmw e34 m50tu but e36 mount arms don't bolt up
  • Crise30
    • May 2013
    • 4
    I got a 1993-1995 bmw e34 m50tu I was using for a swap but the left mount bracket (arms) from a e36 m50 don't bolt up help me plz don't know what to do
  • gazellebeigem3
    • Jun 2005
    • 3712
    maybe some pictures would help? So we can laugh at you and tell you what you are doing wrong
    • iansane
      • 1342
      Did you turn it upside down?
      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
      • arams325
        • 325
        are only 2 of the holes threaded on the passenger side of the block? i am pretty sure the left side arm will bolt on right side up or up side down
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          You are using the wrong set of holes. E36 arms use different holes on the block then the E34 arms.
          • adam325i
            • 20
            Look for 2 rusty holes, clean them and re tap. Install mounts and golden!
            • Crise30
              • May 2013
              • 4
              Thanks I saw the other mounting points for the e36 arms
              • arams325
                • 325
                what size tap did you use for the 2 rusty holes my threads seem to be completely gone, is it ok to tap to the next size larger?
