Need Help
  • Ravins
    • Aug 2005
    • 128
    Need Help
    I cant get the motor far enough back to bolt up to the sub-frame it is like 1/4-1/2inch away o yeah this is a m50 into a 1991 318is
    Sold-87 325
    BBS RK Wheels
    H&R Cup Kit
    E30 ///M3 Light up knob
    Clutch Stop
    ///M Roadster FloorMats
    Jim C Chip
    91 318is
    M50 Swap
    Headers
    UUC Underdrive pulleys
    K&N 3in Cone
    Jim C Chip
    Soon H&R Coilovers
    BBS RS
  • Addissimo
    • Mar 2004
    • 1820
    Did you pull the insulation off of the heater fan cover?
    Are you using a load leveler?
    The engine has to be pretty much parallel with the ground to make it to the mounting holes. Try tilting the rear of the engine up even 2 degrees. It can make the difference.
    Before you get too carried away, make sure your engine mounts are oriented the correct way. It'd suck to get it where it'd fit, then have the turn the engine mounts around.
    -Addis
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • 1990m3
      • 1180
      i just put an S50 in a 318is three weeks ago. You don't need to pull the insulation off the heater fan cover, mind doesn't touch it at all.
      Make sure you're motor mounts are loose on the mounting arms, so you can guide them into the subframe easily.
      You say you can't get the motor far enough back...what is it hanging up on??
      • Ravins
        • Aug 2005
        • 128
        I dont know I am not using a load leveler and sun bitch keeps on lay sideways were one arm will be high up so I am always trying to fight the motor at the same time and which way do the motor mounts need to go is it long threads up or short threads up
        Sold-87 325
        BBS RK Wheels
        H&R Cup Kit
        Clutch Stop
        Jim C Chip
        91 318is
        M50 Swap
        Headers
        K&N 3in Cone
        Jim C Chip
        Soon H&R Coilovers
        BBS RS
        • 1990m3
          • 1180
          I used E28 motor mounts and theres is a tab and a stud. The stud goes to the outside.
          • Ravins
            • Aug 2005
            • 128
            yeah I got those too
            Sold-87 325
            BBS RK Wheels
            H&R Cup Kit
            Clutch Stop
            Jim C Chip
            91 318is
            M50 Swap
            Headers
            K&N 3in Cone
            Jim C Chip
            Soon H&R Coilovers
            BBS RS
            • 1990m3
              • 1180
              I didn't use a load leveller either, and my motor dropped in perfectly balanced left to right with chains on the front and rear hooks built onto the motor. The gearbox was attached when I did it also, hardest part to clear was the front swaybar, but I thought it really went in there pretty easily.
              • rede30
                • 4697
                Yea the one time i dropped in a s50 it took some time but it went in. I think we took the sway bar out when we did it and i put a jack under the tranny, which was conected, and lifted it up while we dropped the motor down.
                • X2theZ3
                  • Mar 2004
                  • 932
                  if you're having problems, just go buy a leveler. They're not that expensive and they are a decent investment.
