Running a 24v Motor Without a BMW
  • KI4UJO
    • Jun 2011
    • 642
    If you read my thread in the V8 swap section, this is basically the same thing. I am contemplating a very unusual engine swap: a M50/52 or S50/52 into a 1965 Dodge D100
    The Truck
    What is coming out of there (it is locked)
    Interior
    So, what needs to be done to run a 24v variant outside of a BMW? I am assuming that I would need:
    Motor
    Trans
    Engine Harness
    Part of the body harness, for ECU and gauge cluster (I do intend to use the BMW cluster)
    all other necessary parts (cooling, A/C?, etc.)
    Being that you guys deal with these all the time, educate me.
    Thanks in advance!
    IMG_0145 by Jonathan Martin, on Flickr
  • DesertBMW
    • Aug 2011
    • 1040
    Looks like that dodge needs a lot of work before you start thinking about engine swap.
    • Wanganstyle
      • 2828
      electronically the engine harness needs power and ground and contains the computer as well.
      fuel pump can be a toggle switch
      mounts for powerplant = custom you are making them.
      dodge looks great for engine swap; you will need the engine/gearbox/drive shaft - just drop it off with the original at a drive line shop after the motor/trans is installed.
      • KI4UJO
        • Jun 2011
        • 642
        Well, actually it now looks like this:
        As for the electrical side, thanks wanganstyle. To ask, does this need a speed sensor feed? I was considering an m60 and it required one.
        • Wanganstyle
          • 2828
          Speed sensor feed is needed for the vanos activation; you could probably rig one up
          Sent from my SAMSUNG-SGH-I337 using Tapatalk
          • nrubenstein
            • 3148
            Why not do an M30? I'd think that the torque curve would be more "right" and it'd look a lot more appropriate in the engine bay as well.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • NbAmTwE
              • Jul 2010
              • 148
              +1 on M30 unless you go s52. Really is this going to be for cool factor? I think the M30 would look the coolest in the truck also. All in all, this seems very interesting and hope your venture goes well.
              UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
              stripped out e30 rally project - in progress
              M50NV -> M50TU E34 swap underway
              • Thujalvi
                • Oct 2012
                • 72
                The engine electronics are relatively self contained, so in a project like this, I'd expect the biggest difficulties to be with things like cooling and the prop shaft, where it's going to be largely uncharted territory, but if you are, or know a properly good fabricator, none of that is insurmountable.
                '93 Daytonaviolett Touring Design Edition
                • KI4UJO
                  • Jun 2011
                  • 642
                  After looking at the options, an m30 seems to fit it the best. As for why I would do this swap, it is for several reasons:
                  1) Reliability
                  2) Fuel Economy
                  3) Why not!
                  • ZekeTheSneak
                    • 1562
                    Wiring will be a cake walk. Its the rest that will be a bitch lol. Engine harness pretty much just needs power and 12v to the starter.
                    • blunttech
                      • 12850
                      This will be awesome with an M30... I had a 64 Power Wagon 4x4 shortbox i stuffed a 340 in. I miss that truck. So ugly it was cool
                      sales@blunttech.com
                      www.blunttech.com
                      Like us on Facebook
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        Bmw inlines 6s I think would be a pig in a truck, maybe m62?
                        M30 would be badass though.
