Spark+Fuel but no start--S50
  • Steven
    • Dec 2012
    • 2305
    :hitler: :hitler: :hitler: :hitler:
    SO my S50 swap is coming near completion, everything is hooked up but I am not getting any spark or fuel.
    I've tried switching out the wire for the ICV and CPS because they are around the same length and easily mixed up with no avail.
    I've tested power on the brown wire coming into the fuel pump and that has no power. I've also tested power on the red/white wire coming out of the main relay on start, but nothing is coming from there, so as a result there is no power going to the green/violet wire for the fuel pump relay.
    All the grounds on the car check out okay so that shouldn't be an issue.
    What's wrong with my carrr
    Okay for no reason, the car starting getting fuel and spark now, but still no start. occasionally it sounds like it's trying to start but nothing..
    Feedback!
    Custom Cup Holder Consoles!
    Calypso Story--S50/Shaved and Tucked Bay
  • ttrousdell
    • Nov 2009
    • 1770
    bad cps or ECU?
    The Build:
    • Nick_S
      • Apr 2011
      • 3658
      Power on the brown wire? I very well could be wrong but I thought all brown wires on the M/S50 harness were ground.
      BTW, I'm having the exact same issue with my nearly done M50 swap. Testing a new DME and CPS tomorrow in hopes it runs.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • Steven
        • Dec 2012
        • 2305
        Originally posted by ttrousdell
        bad cps or ECU?
        ECU came from a running car that I myself pulled.
        Brown wire going directly to the fuel pump.
        How do I test the CPS?
        Feedback!
        • Steven
          • Dec 2012
          • 2305
          I tried testing my CPS but I didn't know which prongs to choose with the volt meter. Anyways I only got a reading with two of the prongs. The volt meter was set to OHMs and on the 200 setting. (the other choices were 2000, 20k, 200k, and 2000k) It read different readings from 30-130 (those are approximate numbers...) From what I understand it should read in the 500 range, but I'm not sure about my settings on my volt meter.
          Feedback!
          • Nick_S
            • Apr 2011
            • 3658
            You are correct. I wish I could clarify which to test but a friend of mine is much more knowledgeable with electronics tested mine. Spec is around 500 I believe.
            05 Honda Pilot
            24V swap thread
            • Steven
              • Dec 2012
              • 2305
              I got the correct setting and did a test. It showed up at 501.
              Feedback!
              • pmat
                • Nov 2012
                • 174
                Had the same problem when swapping in my m50, look for a 2nd green wire at the c101, i beleive its pin56 on the ecu. needs hooked up to ignition
                318is, m50tu g240 s3.46
                • Steven
                  • Dec 2012
                  • 2305
                  Would a cam position sensor cause no fuel no crank?
                  Feedback!
                  • Steven
                    • Dec 2012
                    • 2305
                    So do what? like spice it in where I made all my other connections?
                    Feedback!
                    • Steven
                      • Dec 2012
                      • 2305
                      just tested the cam pos sensor for ohms and it read zero. I had another laying around and tested that and it shout up to like 1,300 so IDK I'll go to the parts sore and see if I can source a Cam Pos sensor with a female end...
                      Feedback!
                      • Steven
                        • Dec 2012
                        • 2305
                        come on guys... I picked up a different cam sensor and nothing. IDK what to check next...
                        Feedback!
                        • Steven
                          • Dec 2012
                          • 2305
                          Even just tried hooking up a green wire onto ignition. still nothing.
                          Feedback!
                          • Steven
                            • Dec 2012
                            • 2305
                            I've narrowed it down. The brown wire going into the main relay is getting ground. The red/white wire coming out of the relay isn't getting power at ignition or crank. This means that the DME isn't giving it the signal to give spark or fuel right?
                            Feedback!
                            • nrubenstein
                              • 3148
                              First thing to do is swap out or at least clean your relay contacts.
                              2002 BMW M3 Alpinweiß/Black
                              1999 323i GTS2 Alpinweiß
                              1995 M3 Dakargelb/Black
                              - S50B32/S6S420G/3.91
                              1990 325is Brilliantrot/Tan
                              1989 M3 Alpinweiß/Black
