M50B25 Swap First Timer
  • eastinthewest
    • Aug 2013
    • 26
    Best advice, get all the parts you need first. Makes it a lot easier
    • Nick_S
      • Apr 2011
      • 3655
      This X100. I made so many small parts orders because I kept thinking I could reuse something or something else would work.
      Also I have heard of people re-using the M42 mounts with decent luck but not E36. I used E28 green mounts and they lined up great.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • FishEye
        • Feb 2014
        • 35
        What are green mounts? Sorry im new to the bimmer lingo
        • Poeman446
          • Jun 2013
          • 227
          These. Part Number: 11-81-1-132-793-M737
          http://www.pelicanparts.com/cgi-bin/...1-132-793-M737
          Although I think I used the black ones that were from a 525. Also Hamburg Technic brand. Part Number 11-81-1-175-735-M737
          • eastinthewest
            • Aug 2013
            • 26
            Funniest thing though. Being in Germany, you would think that any parts store would have them. I had to go to 3 before anyone could even order them for me.
            • eastinthewest
              • Aug 2013
              • 26
              At the shop now trying to figure out what I want to do about the brake booster issue. I know there are probably threads on this specific thing, but I'm trying to find one with step by step instructions on haw to move it. I want to keep the stock one.
              My question is what to do about down by the pedals once the booster is slightly moved to the right?
              • Nick_S
                • Apr 2011
                • 3655
                I'll be honest. I didn't touch mine. I ground the fins off my intake manifold, used 1/4in body shims on the motor mounts. It's close but I have clearance.
                05 Honda Pilot
                24V swap thread
                • eastinthewest
                  • Aug 2013
                  • 26
                  Well going to find the extra clevis tomorrow at the junk yard. Should be an easy fix. Or like you said just grab some shims from the hardware store.
                  • franky2fingaz
                    • Aug 2012
                    • 117
                    You shimmed both mounts?
                    • Nick_S
                      • Apr 2011
                      • 3655
                      Yes. I've read of people doing just one side. I did shim the drivers side slightly more.
                      05 Honda Pilot
                      24V swap thread
                      • delamaize
                        • Nov 2013
                        • 1452
                        FYI. USAG Baumholder's parts yard is a lot better than the yard at ramstien. It's not too far away, they almost always have at least a whole row of BMWs (or then did when I left in late 2012) and more waiting to up put out for parts. Also the auto craft center there is a lot easier to work with, and they are a lot friendlier there.
                        Dumpster Fire Pilot
                        • eastinthewest
                          • Aug 2013
                          • 26
                          So yesterday I moved the booster and decided to do the custom welded clevis method. I pulled one from the yard and cut it and had it welded. Fit perfectly. There some fitment issues with the booster and the holes I drilled but with a little finesse, I got it to work. Note you may have to cut one of the studs off the booster. There is a bracket in the way and without pulling the entire pedal assembly and cutting certain spots on it as well.
                          Now comes the part I dread the most. The wiring. So, because I am lazy, can anyone just post a good step by step how to on the wiring portion? Preferably one with lots of pictures because I'm a dummy. Help is appreciated, thanks guys.
                          • eastinthewest
                            • Aug 2013
                            • 26
                            And by wiring I mean the splicing portion. Not the actual connecting of the plugs, I got that.
                            • eastinthewest
                              • Aug 2013
                              • 26
                              This may be a NOOB issue. I thought I had an M20, but I actually have an M40. So my issue is finding the pin out conversion so I can solder the connecters from an M40 to M50. PLEASE Help me!
