Should i change the head gasket?
  • Mistawall
    • Dec 2013
    • 319
    What do you guys think?
    Valve cover gasket looks new
    Thoughts?
    my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
  • justin_l_
    • Jun 2007
    • 1079
    Compression check? The valve cover gasket above it is leaking. What are your plans for the motor?
    • Mistawall
      • Dec 2013
      • 319
      Thats on my todo list. Its gonna be my daily driver but im probly gonna beat on it to an extent (i will be a lil to excited not too once its running) its got about 180,000 on it so i figure if ima do some routine maintenance now is the time. But ive had a few people tell me if it runs just leave it....
      • MyE30
        • Sep 2013
        • 326
        like justin stated a comp test will give you an idea if you are going to need to pull the head.
        it does look like the oil came from something higher than the head gasket (valve cover gasket). if something is leaking from the head gasket a lot of times it's antifreeze.
        • Mistawall
          • Dec 2013
          • 319
          Maybe thats why the valve cover gasket looks new. Maybe it was replace because of that issue i did scrape some oil dirt off the areas around the intake ports
          • Wanganstyle
            • 2828
            its out of the car; have the head rebuilt professionally and Change every gasket and wear item before install would be the logical and smart thing to do.
            change nothing and just hope it is ok is the r3vtard method.
            Both will cost u time and money. R3vtard method costs alot more time and money in the end equation.
            • Roland H
              • 4480
              Bingo. Take it off, get a valve job done, guides if it needs em, resurface to clean up the surface and eliminate any warpage. New gaskets all around. Check the chain guides too. weld that oil pump nut.
              • Wanganstyle
                • 2828
                160-200k miles is about when the 24V heads need to be rebuilt; and the head gaskets go.
                cylinder heads are wear items; same for gaskets. This is why they are designed to be REPLACED.
                • e30rapidic
                  • 2167
                  Engine is out, I would. I tore down and completely rebuilt my S50 before I put it in.
                  '87 325ic, powered by S50.
                  • MyE30
                    • Sep 2013
                    • 326
                    who do you think we are? BMW owners? "aint nobody got time for dat!"
                    isn't the R3vtard method to just put the motor in and when it blows at 250k put in another 180k motor?
                    • Wanganstyle
                      • 2828
                      The r3vtard method is to install a blown motor from the beginning because doing a leak down test is unfathomable.
                      Sent from my SAMSUNG-SGH-I337 using Tapatalk
                      • ParsedOut
                        • Sep 2005
                        • 1437
                        Leak down test? Is that where you continue to dribble a little bit after taking a piss? I might need to get one of those tests done...
                        • Mistawall
                          • Dec 2013
                          • 319
                          ok well i guess im going to do a leak down test then go and contact the Machine shop too see what the damage will be to rebuild the head. im curious what other people have paid? i had my m42 rebuilt once and they charged me 380 bucks. im assuing this will be a bit more exspensive.. maybe 5-600?
                          and since the head will be off i guess might as well replace the piston rings? lol sounds like the logical thing to do.. oh boy ive gotten myself into an expensive mess haha.
                          • MyE30
                            • Sep 2013
                            • 326
                            if your compression checks good across the board and cost is a driving factor you could leave the piston rings alone. if done by the book, replacing piston rings would cause you to have to at a minimum hone and clean the block, replace the rod bolts, replace the main bolts, and potentially replace the rod and main bearings. $$$
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              If the head gasket is only leaking coolant, a leak down test won't tell you anything. The gasket would had to have into one of the cylinder bores for a leak down test to tell you anything.
