Fender's M52 E30 Build
Alright, so I received my TRM kit.
So, how does everything get hooked up and mounted? Is my ICV right?
Should I trash everything left on the OBDII manifold? And lastly, what did I hear about the IAT sensor? Where does it go?
Untitled by fender13bender, on Flickr
Untitled by fender13bender, on FlickrTurbo Build HereComment
Got some bad news, I took the valve cover off and oil pan off today. I found broken timing chain tensioner pieces in the oil pan, and pulled out the broken piece from the timing chain area. Thoughts? Engine made no noises when it was running in the 328.
ZF showed up!
Going to freshen it up with all new seals, clean it, and drift pin sets.
No idea on the driveshaft yet.
Updates:
Cams removed from M52, and S50 cams removed from M50. The M52 is dirty, really dirty and sludgey. You can see the difference between my old M50 and this M52.
I also cleaned up a spare timing cover to install, and picked up my powdercoated valve cover, thermostat cover, oil pan, and oil filter housing. I was thinking of doing the timing cover but nah, won't see it.
Can I swap my M50 cam trays into the M52? I already have them resting in place, and everything looks good. I'd much rather use them because they are clean and I know they were taken care of (by me).
I have a big order from ECS coming in that should allow me to get the engine buttoned up. I should have more done tomorrow.
You can see how much cleaner my M50 head is, as well as the cams and trays.
1 or 2 broken guides on the M52.
Too bad I ordered an M52 valve cover set before I decided to switch.
I'm currently in the midst of my swap too. M52 + ZF into '84 318i. Been testing fitting driveshafts and found a E36 328i works best. Center support bearing will need to be switched out or you will need to thread the outer holes to get it to bolt up.1984 AW 318i - aka RuntComment
S50 cams and trays installed, timing set (hopefully right) oil pan and valve cover installed. Getting closer!
Drilling oil pump nut
Wire tied
Powder coated oil pan and valve cover
What are you doing for wiring? It seems the older cars aren't swapped as often as the newer ones.Turbo Build HereComment
Trust me and just have Markert (328iJunkie) do the wiring for you. I have an 84 318 with and M52 motor with S52 cams. Lots of odd little weird quirks, that makes it worth it to just pay and not worry.Simon
Current Cars:
-1966 Blue Boat
-1969 Red VW
-1986 White BMW
-2006 Green Thing
Make R3V Great Again -2020Comment
