What's the torque spec for oil pick up tube??
  • ksjdan
    • Jul 2012
    • 330
    I am currently in the middle of the swap, and I cant seem to find the torque spec for the oil pick up tube.
    Bolt # 13 in the picture
    My 1990 325is Build Thread
  • MyE30
    • Sep 2013
    • 326
    if the bolt you have is a M6x20 bolt then the torque is 10 Nm.
    Forgot to add the reference:
    AZD 11 41 3AZ
    • ksjdan
      • Jul 2012
      • 330
      AZD 11 41 3AZ
      Thanks man! :up:
      • Poeman446
        • Jun 2013
        • 227
        Shoot... I hope I got mine right. I remember I couldn't find the torque spec on it, but I don't remember what I torqued it to. I think it was around 10 Nm or possibly higher. Hopefully not too terribly much higher.
        • AndrewBird
          The Mad Scientist
          • 11898
          If it didn't break off, you are fine. In a case like this, the torque spec is there purely so you don't break anything. Most mechanics would tighten something like this by hand without a torque wrench because as long as it is tight, it is tight enough.
          Stretch bolts or a pattern of bolts (like wheel lugs) and a few other random fasteners are really the only thing that NEEDS a torque wrench. Important bolts, like flywheel bolts, that have a higher torque rating also need a torque wrench just so you know you got them tight enough.
          • Poeman446
            • Jun 2013
            • 227
            Understood. I just figured that this gasket was pretty critical. I didnt want over tightening to warp the gasket or something. I'm not sure. I just didnt want it to leak and cause me to lose some oil pressure. I think its fine though. Thanks!
