M50 with S50 cams and G250 with S3.73 will this be a good set up?
  • amcink
    • 788
    OK I got everything ready to go and want to know if I have a decent set up for a DD
  • franky2fingaz
    • Aug 2012
    • 117
    3.73 & 1:1 5th gear = high revs on the highway, at least for me... I'm keeping my 2.93 or maybe 3.15 ...
    • Coyote_ar
      • Sep 2009
      • 175
      with 195-60-14 tires, you will be running over 4k rpm @ 80mph
      if you are confortable with that, it should be quite a rev happy and agile car.
      ---E30 320i Hennarot 1984 Sedan---
      • getouth
        • Jan 2010
        • 3343
        Seems a bit high especially for a DD IMO
        FEEDBACK:
        http://www.r3vlimited.com/board/showthread.php?t=316212
        BMWCCA #398608
        IG @yagayo38
        "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
        • justin_l_
          • Jun 2007
          • 1079
          G250 trans are junk, very weak. I would want at least 3.25 gears if I planned driving 55 or higher.
          • amcink
            • 788
            G250 is what i got to work with and no more money for a new one. i'm running 16" wheels - Therefore it seems that in the near future after my swap i will need to get at least a 2.93 is this correct? or is there a better choice since I will be tunning it with a chip and we expect to get 205 hp
            • emmanuel.dlc
              • Jun 2011
              • 144
              i'd say 3.25, thats basically a g260+3.73
              • amcink
                • 788
                Do you know which cars had the lsd 3.25??
                • justin_l_
                  • Jun 2007
                  • 1079
                  M coupe
                  • amcink
                    • 788
                    Originally posted by justin_l_
                    M coupe
                    E30 or E36?
                    Do you know the part number?
                    • mitchlevy7
                      • Aug 2011
                      • 672
                      Originally posted by amcink
                      E30 or E36?
                      lol
                      www.cp-e.com
                      1989 Zinno 325i m52 turbo coupe
                      2015 Ford Fiesta ST, Daily Driver.
                      • amcink
                        • 788
                        Originally posted by mitchlevy7
                        lol
                        We are learning here!!
                        • Wanganstyle
                          • 2828
                          3.15, 3.23 are the stock e36 m3 final drive ratios
                          3.15 is the final drive of e36 325i manual (it has a m50+g250)
                          I run a 3.46 final drive in my e36m; it had a 3.23 stock. 17" tires
                          My 325i 5 speed with g250 had a 3.15 in it stock; I put in a 3.46 yesterday. 16" tires
                          Anything between 2.93-3.46 is ok for street everyday use; if you have small rolling tires then go toward the lower side.
                          Sent from my SAMSUNG-SGH-I337 using Tapatalk
                          • amcink
                            • 788
                            Thank you Wangan - always coming trough
                            I'm running a 16" tires and it seems that a 3.15 will be easier for me to find than a 3.23
                            • Wanganstyle
                              • 2828
                              No problem. Final drive is a personal preference; I say run what is available to you and adjust to your own liking
                              3.73+g250 will be annoying but great for smoking tires
