My M50/G260 shifter carrier
  • Phil G
    • Jan 2014
    • 3
    Hi,
    I just finished my first swap. Installed an M50b25tu with the M20 G260 tranny.
    I just thought Id share what I did with the carrier.
    I just went to a welder with the idea an he welded me two plates.
    I drill hole and mount them into the chassis.
    Untitled par Philippe Gélinas, sur Flickr
    I slotted the hole in the chassis so I can move the carrier front and back. I can really put the lever where I want from front to back with the carrier.(Would be nice with a X5 lever, no need to bend the lever)
    I bend the selecting rod like everyone else did.
    IMG_2819 par Philippe Gélinas, sur Flickr
    I'm on solide mount, Id not run this setup without at least solid tranny mount and my car's rought on the edge I dont mind drilling hole in it. Id probably not do that on a mint garage queen car.
    Hope it can help!
  • acolella76
    • 2950
    Looks great! I did something similar with the early model shifter carrier and it feels spectacular
    -Alex
    • Phil G
      • Jan 2014
      • 3
      Thanks!For real it feels amazing! Which I had an X5 lever its b/o at my local dealer
      • emmanuel.dlc
        • Jun 2011
        • 144
        very nice, i will do the same but with the early carrier:
        *img is not mine
        • Bmwdayz
          • Apr 2011
          • 610
          Looking good!
          • Ocell
            • Apr 2013
            • 291
            I've been wondering why BMW didn't triangulate the shift carrier attachment points. Nice solutions here.
            91 318is Members' Rides Thread
            • DTMbimmer07
              • 1485
              Is this necessary to do if you use the g260? Haven't seen this before.
              • emmanuel.dlc
                • Jun 2011
                • 144
                not necessary at all, just a good mod!
                • emmanuel.dlc
                  • Jun 2011
                  • 144
                  i guess to avoid any problems due to shifting issues while the engine/tranny is moving with bad mounts.
                  if the shifter is solid like this, there is a chance (using soft mounts) that the gears start poping out by themselves by the movement of the assembly and/or miss shifts.
                  with the carriers as bmw designed, the shifter will move along with the tranny and not with the body, thus 'no miss shifts' and no gears poping out.
                  i hope my understanding answered your question.
                  • Ocell
                    • Apr 2013
                    • 291
                    Yeah, that makes a lot of sense. I didn't think of the movement from stock mounts.
                    They still could have put two attachment points on top of the transmission with the single bushing on the chassis as-is. But they've engineered cars a lot more than I have.
