s50 swap driveshaft questions
  • iflytii
    • Jun 2004
    • 482
    You guys have a TON of great info over here!!!
    I am preparing for a s50 swap and while it's pretty common knowledge while using the e36 m3 5spd I will need a e30/m3 driveshaft. However, I ran into an slight problem. Having no luck in the used arena, I found a reasonably priced re-build BUT, there are 2 different drive shafts available for e30 m3! A 87 and older or 88 and newer and everywhere I search simply says "use a e30 m3 drive shaft". For those of you who have done the swap using a e30/m3 driveshaft, which did you use???
    Also, I ran across these guys while looking for a rebuilt drive shaft:
    Replacement BMW Drive Shaft with new U-joints, CV joint and center support. Our BMW Driveshaft is balanced at 3500 RPM and includes free shipping & warranty
    They have an "A" rating at the bbb but since their prices seem to be very good I was curious about their quaility. If anyone has any good or bad experience with them I would love to hear about it.
    Thanks!
    Bob
  • 1990m3
    • 1180
    bob
    i used a 1990 driveshaft with the same setup you have...s50 motor, e36 m3 trans, e30/e28 diff. It was a tight squeeze (E34 M5 guibo is a little fat) but it all went together no problem.
    • hugh jass
      • 2220
      You might want to check these guys out for a rebuilt driveshaft. They are very well known and do lots of European brands.
      I have a core if you need it for exchange purposes with them.
      ______________________
      ex-Chief Operating Officer
      Blunt Tech Industries
      West Coast and Pacific Rim
      • iflytii
        • Jun 2004
        • 482
        Thanks guys!!!
        • aeryk7
          • Oct 2005
          • 616
          e36 325 manual driveshaft works also
          253rwhp
          My Vids(OLD)
          http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
          http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
          • hugh jass
            • 2220
            According to what I've read, that works (only?) with the regular E36 325 Getrag tranny.
            • FredK
              • 14761
              What about using the ZF 5 speed driveshaft, then?
              If the E36 Getrag driveshaft works, why shouldn't the ZF 5 speed driveshaft?
              • rede30
                • 4697
                I have a e30 m3 driveshaft that has worked with a 95 m3 tranny
                • aeryk7
                  • Oct 2005
                  • 616
                  E30 M3 driveshaft and e36 325is driveshafts will both work on the getrag 240 it is posted on AKGmotorsports that the 325is will work on the 240
                  253rwhp
                  My Vids(OLD)
