s50 down
  • E30FreaK89
    • Apr 2006
    • 437
    s50 down
    Hey guys, so the other night I was ripping through the gears. The engine ran bitchin but at the top of third around 6-6.5k it let go and ate some valves :/. Bumbed because I just got it running and on the road. I want to get your opinions on going about fixing the engine or just getting a new one.. if I go at getting a new engine I'm afraid this will happen again so I would want to tear it completely apart. With that kinda money I might as well do a s54..
    Any opinions would be awesome.
    Thanks Gary
  • Nick_S
    • Apr 2011
    • 3655
    Rebuild the motor you have if you're going to spend the money on it. Or find another s50 and swap it in.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • vandy
      • Nov 2011
      • 130
      +1 for a rebuild. You don't know the condition of the potential new swap motor like you know the motor you own now. Unless you're buying from a known trusted person or friend, stick with what you've got. IMHO.
      • acolella76
        • 2950
        You're still going to spend about $7-10k if you swap in an S54, and probably $2-3k if you rebuild your current motor. Just find another S50 and drop it in.
        -Alex
        • JOMARO
          • Mar 2006
          • 116
          buy another S50 , and have this one as a spare or even part it and refund some money back
          • 328ijunkie
            • May 2007
            • 3961
            many S50's have weak retainers. I would attempt to fix whats in there vs picking another one up that may have the same issue....
            Check Us out on Facebook
            Full Product Line Tuning
            • e30rapidic
              • 2167
              buy another S50 and update the retainers....
              '87 325ic, powered by S50.
              • mikegar
                • Aug 2005
                • 523
                Part out the s50. Replace with s52.
                Originally posted by Ferdinand
                I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
                DIVING BOARD DIVISION DIVISION IDIOT
