Finally got the motor and trans bolted in tonight - it was a TIGHT fit. I decided to run the CSS power steering blockoff and deleted the whole pump assembly. I also decided to delete the A/c, but can always add that later on. Trying to offset the weight I added from the s50 over the s14.
I really don't see any way that I can run a mechanical fan and a radiator. I'm thinking that an electric pusher fan in front of the radiator might be the way I have to do this.
Can someone help me with the proper radiator/fan/expansion tank/cooling pipe setup? I was told and e36 radiator is good, but I would prefer something with aluminum end tanks. How about a s54 z3 M roadster/coupe radiator? Do I need any special bracketry to mount the radiator?
Also, anyone have a source for replacement tie rod end boots? My tie rods are in good shape, but the boots are torn, I don't really feel like having to get new tierods because of torn boots.
Thanks.
Thanks.
