e34 oil level sender: Physical Pin location and number
  • mpowerful
    • Jul 2013
    • 1273
    Well I know how to wire it and where to wire it on c101 but one thing that I dont know, and maybe im just dumb, is the physical layout of plug. Which is pin #1 and pin #3? Pin 1 toward the front or rear of motor.
    I have a 3 prong connector from e36 donor harness and want to wire it up through c101 through the harness. I already go the Pin 1 to c101 2, pin 3 to c101 10 and ground middle pin. Just need to know which is pin 1 and 3 literally.
    Picture for reference. Ignore the broken plug end. Probably will use it anyway. Damn things expensive new.
  • mpowerful
    • Jul 2013
    • 1273
    Someone?
    • Mistawall
      • Dec 2013
      • 319
      maybe you can check polarity? with a multimeter? im curious tho because i will need to wire this aswell
      my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
      • camshaftgsxr
        • Aug 2011
        • 416
        if you have it wired to a three prong female connector just plug it in, if the light goes out then its right if not then switch #1 and #3, that's how I had to do it.
        BroWorks.com Bro is a lifestyle
        • mpowerful
          • Jul 2013
          • 1273
          Wellll. I dont wanna have to splice it twice after its in the car. Hahaha.
          • meanEG
            • Oct 2013
            • 562
            i just did this tonight. pin 2 is ground. the pin 3 goes to black/blue wire pin 2 on c101, and the pin 1 goes to violet/green pin 10 on c101. good luck
            Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
              • 34844
              Look in the ETM?
              The engine harness colors are blue/white, brown, and blue/yellow.
              • meanEG
                • Oct 2013
                • 562
                Originally posted by nando
                Look in the ETM?
                i dont think he is using the e34 or e30 oil level harness plug
                • mpowerful
                  • Jul 2013
                  • 1273
                  I am not. I am using a plug I cut off the m52 and running it through the e36 obd1 harness.
                  • meanEG
                    • Oct 2013
                    • 562
                    You will have to add at least 2 new wires for static and dynamic. Ground where ever you want. I gave you the pin locations. The numbers won't change on the pin locations, regardless of where the plug came from.
                    EDIT: Just reread your first post. Looking at the face of the connector with metal on top, pin 1 is on the left.
                    • mpowerful
                      • Jul 2013
                      • 1273
                      Ahhh cool thanks man. Yup already have the static and dynamic wires run through harness and pinned in c101. Just need to splice in the plug.
                        • 34844
                        So? The ETM will tell you which pins to hook up. :)
