E30 S50 no start - no spark/no fuel
  • e30austin
    • 15382
    #31
    Now I know this. Just seemed lame as fuck to me.
    • Matt-B
      The Waffler
      • 3856
      #32
      Yea, my m42 years ago did this, dug into stuff to find pointless wiring lol
      • wakdog
        • 223
        #33
        I don't think the OBC relay will be my issue, Im getting 12v to the main relay and my ICV buzzes and everything that the main relay turns on has power... just no FP relay action :(
        90 318i M62B44 OBD1
        02 530i Touring (Airlift 3P)
        • M3PO
          • May 2012
          • 537
          #34
          You can test the functionality of the FP relay by using a piece of wire to ground the 86 pin on the relay. This is what the DME does to trigger the relay. If the pump kicks on, the relay is good and the issue is related to the DME.
          In my case, the DME was not triggering the FP relay because EWS was telling it not to. :hitler:
          • Maschine3
            • Jan 2014
            • 9
            #35
            Solved?
            I have the exact same problem. The E30S50 cranks but won't start. Double checked all wiring, grounds, relays, fuses, chip for ews, and dme is good. How did you solve your problem? Thanks in advance.
            E30 1990 325i
            E39 2001 530i
            • Maschine3
              • Jan 2014
              • 9
              #36
              Will PayPal $ to someone with an answer
              Anyone in Wisconsin who knows the e30s50 swap please help. Crank but not starting. In addition to my last post I got a new red label dme and new engine harness and still having issues. I live in Appleton, WI. I am serious and will PayPal money or pay cash to the person with answer or help.
              E30 1990 325i
              E39 2001 530i
              • Classicoe30
                • Apr 2012
                • 205
                #37
                My friend had a the same problem! At first It would crank but wouldn't turn or run I should say! And all of sudden it would even crank anymore! Everything was check for connection and re checked again! The problem was in the ecu the war chip was not making full contact ! Problem solve! I would recommend to check your ecu and programming ! Good luck !
                • sweet3
                  • Oct 2012
                  • 753
                  #38
                  The fuel lines are one of the easiest mistakes that can be made. Check your fuel lines. If you pressurize the tank, you will find the "return" line. The feed line is the line that is connected to the fuel filter near the back of the car. The feed line needs to go to the fuel rail closest to the firewall.
                  Hope this helps
                  PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
