E30 S50 no start - no spark/no fuel
  • e30austin
    • 15382
    Customer's 1991 318i sedan with 1995 S50B30 US engine has a no start condition after swapping in engine. Harness is from the same manual '95 M3. 413 red label DME with TRM tune. Modified C101 plug (by me). All sensors are brand new.
    Car cranks, no spark. I do not hear the ICV hum or the fuel pump turn on.
    So far, I have double checked the following:
    -engine arm/frame rail ground, coil pack/valve cover ground, engine harness/battery tray ground, injector/VANOS ground, and DME ground into the bracket.
    -CPS tests out at a good 540 ohms
    -swapped 413 red label DME and all relays from my running/driving S50 swapped car
    -good 12.5 volt connection at the battery tray
    I have double checked all my C101 connections, and here they are:
    318i C101 Pin Color Function E36 X20 Pin Color
    1. blu (alternator) 25. blu
    4. brn/wht (CTS) 12. brn/vio
    5. brn/grn (oil pressure) 23. (blk/gry)
    7. grn (ign switch) 21. grn
    8. wht (fuel rate) 24. wht/blk
    9. blk (engine speed) 20. blk
    11. wht/blu (SI reset) 19. wht/grn
    12. brn (CEL) 8. gry
    13. grn/vio (fuel pump) 13. grn/vio
    14. blk/wht (vehicle speed) 14. blk/wht
    15. blk/grn (unloader relay/starter) 15. blk/grn
    16. wht/blk (DME diag conn) 17. wht/vio
    18. blk/yel (ign switch) 18. blk/yel
    20. red/yel (ABS) splice switch from e36 main relay
    The wiring seems correct to me, but I'm kind of at a loss. All help appreciated. I'd just like this car to leave my shop soon.
    Edit: I have also confirmed proper placement of the trigger wheel, and it is lined up properly with the keyhole. FYI
  • Batz
    • Aug 2013
    • 303
    I had a very similar problem with my e30. I had no spark and no fuel. But the car would crank. My issue was the bad OBC, for some reason the anti-theft system turned on, and wouldn't let the car start. When i disconnected the OBC the car started right away. I'm not sure if that will help you with the car in any way, as mine is just stock e30 with stock m20 in it, but figured might post it anyway.
    • e30austin
      • 15382
      Thanks, but this car doesn't have an OBC.
      • e30austin
        • 15382
        Bump.
        • e30austin
          • 15382
          Anyone?
          • justin_l_
            • Jun 2007
            • 1079
            Just quickly took a peek on lunch, double check 20 on the e30 side. Looks as if it is supposed to go to the ABS, not coolant temp.
            Page 23
            • e30austin
              • 15382
              Thanks, Justin. I revised my wiring. Here it is:
              • luckysnafu
                • Jun 2008
                • 262
                You've got a couple problems with your C101 wiring, but I don't think that should prevent the car from starting.
                C101
                Pin 4 - This needs to be wired to an e30 temp sensor (brown top, one wire) to get the temp in the e30 cluster
                Pin 14 - Speed Input Signal - Not sure what this connects to on an S50 (pin 9 on M52/S52)
                Pin 20 - ABS Unit - Should be connected to a switched +12, preferably from a relay (I have mine hooked up to the main relay)
                The 318i/is didn't have any wiring for oil level, so you don't have to worry about that, unless you are swapping in a check panel.
                M/S52 Wiring Diagrams
                Z3M S52 to late model 325i wiring diagram
                M52 to 318is wiring diagram
                • e30austin
                  • 15382
                  Up
                  • justin_l_
                    • Jun 2007
                    • 1079
                    Power and grounds good? Cut back the covering to double check?
                    • Nick_S
                      • Apr 2011
                      • 3658
                      My CPS tested well within spec but the car wouldn't start. Replaced it with a brand new one and it fired right up....but you're saying the sensors are all new so I doubt this would be your problem. Tried a different DME? Double check your grounds?
                      91 318is M50 swapped
                      05 Honda Pilot
                      24V swap thread
                      • e30austin
                        • 15382
                        Yup, done all this. Swapped DME and various relays from my car to no avail.
                        The car has some bullshit alarm system in it. The unloader relays are all turning on, but I wonder if that alarm is doing something funny and causing it not to start (since it taps into the ignition switch...)
                        • Slovik
                          • Jan 2010
                          • 198
                          Maybe something simple like a main relay?
                          • delamaize
                            • Nov 2013
                            • 1463
                            Time to rip and tear out that stupid alarm, and kill it with fire.
                            Dumpster Fire Pilot
                            • Ekisto
                              • Apr 2014
                              • 19
                              Did it start? im in the same place as you. Everything seems to be conected correctly.
                              Cheers from Chile.-
